Temporary Window Pane Insulation - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Nealtw
Old 07-01-2020, 09:26 AM   #1
Rewards Points: 36
My AC is broke and I'm having a heck of a time getting it fixed/replaced. I'm trying various things to keep the heat out, particularly on the southwest side of the house. I had white paper taped to the window with a sheet of some sort of foam board insulation. However, I'm concerned it's absorbing heat making it hotter in the room. How should these foam boards work? Or should I not use that?
I don't know exactly what the material is, but it's yellow-ish with silver backing. I got it for free 10 years ago and can't read the writing as it's mostly faded. It is a legitimate piece of insulating material. It's not some cheap craft foam or anything like that.
blu878 is offline   Reply With Quote
Old 07-01-2020, 09:35 AM   #2
Rewards Points: 461
Re: Temporary Window Pane Insulation
Preferably you would temporarily block the light on the outside of the house, before that heat even passes through the glass. Could be as simple as cardboard.
XSleeper is offline   Reply With Quote
Old 07-01-2020, 09:38 AM   #3
retired framer
Rewards Points: 626
Put the silver to the sun to reflect it.
Insulation is supposed to absorb heat instead of letting the heat go thru. If it is getting warm all the way thru, it is working but just not thick enough for what you need.
Windows on Wash likes this.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 07-08-2020, 07:44 PM   #4
Rewards Points: 50
If something like HOA rules don't prohibit, try good old aluminun foil on the inside so the shiny side can reflect out. That should do better than white paper. Keep the foam board up after installing the aluminum foil.
NeoHawk is offline   Reply With Quote
