Sub Basement Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 11-13-2017, 08:32 PM   #1
Rewards Points: 32
I recently moved into a older home and ripped out all ceiling tiles, insulation, paneling, carpeting, etc. in basement but left behind all framing for walls.
questions.
1. Best approach for RIM joist insulation?
2. Are these close foam kits are hardware stores hard to use for RIM joist insulation?
3. Best approach (batt or insulation board) to replace insulation in wall framing area between basement wall and future paneling?
4. Do you avoid vapor barrier in sub floor insulation?
ken57 is offline   Reply With Quote
Tags
rim
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 04:42 PM
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 05:44 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
