Spray Foam, That Will Not Attack Vinyl Siding - Insulation - DIY Chatroom Home Improvement Forum
Old 05-09-2012, 12:32 PM   #1
34Ford's Avatar
Question
Spray foam, that will not attack vinyl siding
Does anyone know of a spray foam like great stuff that will not eat my vinyl siding?
I know for a fact great stuff will. I'm trying to fill small holes to keep the darn wasps out.
34Ford is offline   Reply With Quote
Old 05-09-2012, 12:45 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 848
Never had any problems with the Hilti window and door foams.
Make sure you spritz the area with water just before and lightly mist it.
It will help speed the cure.
Old 05-09-2012, 01:05 PM   #3
34Ford's Avatar
Ah, good to know. I will have to look for it.
Old 05-09-2012, 09:17 PM   #4
Rewards Points: 1,858
http://www.dap.com/product_details.aspx?product_id=11
Vinyl Siding Help Needed swiederin Building & Construction 4 10-24-2011 09:02 PM
Insulated or Non-Insulated Vinyl Siding? dv817 Building & Construction 17 07-31-2011 05:46 PM
vinyl siding over wood siding loyal Building & Construction 6 05-26-2009 12:17 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
