Spray Foam Question - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By chiraldude
Old 11-22-2018, 11:11 AM   #1
Rewards Points: 16
Spray Foam question
Hey Folks,
Looking to spray foam my 12x12 cabin. The cost is quite a bit more expensive but the mice got into my previous rockwool insulation, so I removed it.
So, if I spray foam the 2x4 walls, do I fully fill the 2x4 gap and then install wood paneling to finish?
If the full 1.5 inch depth of the 2x4 isn't covered, will mice get in behind the paneling? Should I make sure that the spray foam is flush with the 2x4 so the paneling is right up against the spray foam to limit mice intrusion?
I hope this wasn't too complicated.
13moe is offline   Reply With Quote
Old 11-22-2018, 11:48 AM   #2
Rewards Points: 943
Re: Spray Foam question
I think it depends on how much you want to spend and/or how much R value you want.
Mice are very persistent and if they want to get through the spray foam, they will eventually chew through it.
One idea would be to place some metal mesh in the wall space before spraying the foam. Small gage wire so it's easy to cut. Tack a strip between the 2x4s every couple of feet.
Msradell likes this.
chiraldude is offline   Reply With Quote
Old 11-22-2018, 03:09 PM   #3
retired framer
Rewards Points: 642
The cavity should be 3 1/2" plugging holes dealing with mice would be a better approach.
Old 11-23-2018, 10:13 AM   #4
APA
Rewards Points: 384
Wold be easier to find where they are coming in and seal the holes up.
APA is offline   Reply With Quote
Poly Spray Foam insulation atvjoel Insulation 1 02-01-2016 12:51 PM
Living/Garage wall and spray foam install question HowardBrown Insulation 4 04-03-2014 09:56 PM
Spray foam in attic diystephen HVAC 6 12-29-2012 01:07 PM
Spray Foam into walls behind kitchen cabinets? MovedTooMuch Insulation 4 09-21-2011 09:33 AM
Spray Foam Installation Problems Ron6519 Building & Construction 7 07-11-2011 01:50 PM
