Spray Foam Option - Insulation - DIY Chatroom Home Improvement Forum
Old 10-23-2015, 09:01 AM   #1
Rewards Points: 16
spray foam option
Hello, I'm in the process of researching spray foam options for my attic roof down to soffits, enlcosing/sealing making a conditioned space. I was just wondering if anyone here has spray foam in their attic particularly between joist of roof line. If so, are the any moisture problems regarding roof sheathing? Two types: open cell and closed cell spray foam, it appears that closed cell is the way to go due to vapor retarder. My house is old (1915). Thanks for any info.
John108 is offline   Reply With Quote
Old 10-23-2015, 09:21 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 856
Where is the home located and what the reasoning behind encapsulating the attic?
Old 10-23-2015, 09:32 AM   #3
Rewards Points: 16
Located in PA. Looking to make it a finished space. 1-it has soffit vents and REALLY old batt insulation (falling apart) with an air gap behind it and then roof. So right now it's a vented attic. Furring strips currently hold up the insulation. My HVAC for upstairs is up there but everything is run around the perimeter including the air handler. The attic has good headroom and can easily be finished.2-I've read open cell spray foam can trap moisture in roof sheathing whereas closed cell does not. I was wondering if anyone has this in their attic.
Old 10-23-2015, 07:43 PM   #4
Rewards Points: 856
I have used Open Cell in quite a few insulated assemblies without issue. The building science will say to use CC SPF given its reduced vapor permeance.
I see no issue with either as long as the ceiling plane is airtight and well built.
You could incorporated a vented design with foam board and channels if you want to go that route as well.
Insulating an Attic - Spray Foam in the Rafters v. Cellulose on the Floor esteve999 Insulation 5 12-13-2014 10:29 AM
Spray foam the interior of a exterior brick wall? Convict3 Insulation 13 08-21-2012 07:01 AM
Spray Foam Installation Problems Ron6519 Building & Construction 7 07-11-2011 01:50 PM
Spray Foam/ Foam Board Hybrid? entropyracer Roofing/Siding 2 09-19-2008 07:12 PM
