Spray Foam Needs A Firebarrier? - Insulation - DIY Chatroom Home Improvement Forum
Old 10-27-2014, 01:03 PM   #1
Rewards Points: 229
Spray foam needs a firebarrier?
I thought i was all set with beginning to apply rigid board and spray foam to insulate the basement rim joists, now i hear you have to have a barrier over the exposed spray foam? anyone know what this is?
davemax is offline   Reply With Quote
Old 10-27-2014, 01:55 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 904
No true when it comes to ribbon boards.
Most froth paks have a fire barrier incorporated into the foam. If you are concerned, cover the exposed foam with fiberglass/roxul. It will only add to the performance.
XPS Foam on uneven basement wall - Pt.2 (no spray foam) jefferyscott Building & Construction 17 01-04-2017 09:27 PM
Spray foam Question b lowell Insulation 4 01-30-2013 02:34 PM
Spray foam in attic diystephen HVAC 6 12-29-2012 01:07 PM
DIY spray foam ACR_SCOUT Insulation 12 12-30-2011 06:57 AM
Closed Cell Spray Foam insulation and hiring a contractor. Spud Building & Construction 2 10-14-2009 09:03 AM
