Spray Foam - Insulation - DIY Chatroom Home Improvement Forum
Old 01-08-2014, 11:50 AM   #1
Rewards Points: 27
Spray foam
I've had to completely renovate my home because of mold and now i'm ready to insulate the 2x4 walls. I was thinking about going around each stud cavity with spray foam and using something like flashing tape on the plywood seams then insulating the wall or should I just skip all that and just insulate the walls? I'm planning on using fiberglass insulation. Good idea or better suggestions?
kujo is offline   Reply With Quote
Old 01-08-2014, 12:06 PM   #2
Rewards Points: 1,854
What on the outside of the house for siding and what's under it?
About how old is this house.
Got a picture of the outside in the area where the mold is?
Old 01-08-2014, 12:12 PM   #3
Rewards Points: 27
Here's a link to what it use to look like http://www.diychatroom.com/f15/repai...r-wall-174828/.
I'm putting metal siding on it with house wrap under it.
House was originally built in 1990 but I have rebuilt and replaced everything but the trusses and floor joists.
Old 11-08-2014, 04:50 PM   #4
Rewards Points: 27
Posted in the wrong forum.com
Old 11-08-2014, 05:11 PM   #5
Spray foaming those walls is not a DIY job.
Should have hired a real licensed plumber to run those lines.
Guess your trying to get by and not getting proper permits and inspections.
This is a one shot deal.
There should be no exposed seams in the outside plywood.
Windows on Wash (11-10-2014)
XPS Foam on uneven basement wall - Pt.2 (no spray foam) jefferyscott Building & Construction 17 01-04-2017 09:27 PM
Spray foam Question b lowell Insulation 4 01-30-2013 02:34 PM
Spray foam in attic diystephen HVAC 6 12-29-2012 01:07 PM
DIY spray foam ACR_SCOUT Insulation 12 12-30-2011 06:57 AM
Closed Cell Spray Foam insulation and hiring a contractor. Spud Building & Construction 2 10-14-2009 09:03 AM
