Spray/expanding Foam In Walls, Good Idea? - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By joecaption
Old 08-04-2016, 05:01 PM   #1
Rewards Points: 16
Spray/expanding foam in walls, good idea?
Hello,
I have a house in southern California that was built in 1954, and has no insulation in the exterior walls. I was wondering if it would be a good idea to drill some holes in my walls to spray expanding foam to help with the heat and maybe help sound proof. It's mainly for my the exterior walls in my bedroom which are on the southern facing side of the house. The walls are made of plaster (if that matters). Sorry, if this had already been answered, but every time I tried to do a topic search, it just gave me everything.
Thanks in advance.
Wookiejack is offline   Reply With Quote
Old 08-04-2016, 06:45 PM   #2
Retired Moderator
Rewards Points: 7,174
Re: Spray/expanding foam in walls, good idea?
You may want to call an insulation contractor in your area---that would be the best place to start.
Special products are used that you might not be able to buy--
One of our contractor members should be able to give you some specifics.-Mike-
Old 08-04-2016, 08:15 PM   #3
Rewards Points: 4,864
I'd be concerned about spray foam damaging the plaster and lath as it expanded, if not the sheathing outside as well.
There are other materials designed for this.
stick\shift is offline   Reply With Quote
Old 08-04-2016, 09:33 PM   #4
Rewards Points: 1,916
Not a DIY job.
What type siding do you have?
Most often this is done from the outside, not the inside.
Wookiejack likes this.
pumping foam in cinder block walls beach_n_rides Insulation 2 03-12-2014 06:41 AM
Rigid foam on basement walls - gap or no gap? spaceman spif Insulation 9 10-19-2013 04:40 PM
Exteriors for rigid foam cladded concrete walls atomicsink Concrete, Stone & Masonry 2 02-14-2013 07:36 AM
Foam vs. Cellulose insulation in walls nhoj Insulation 10 12-19-2012 06:56 AM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 01:20 PM
