Is Some Insulation Better Than No Insulation? - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-11-2016, 08:46 PM   #16
Usually Confused
lenaitch's Avatar
Rewards Points: 74
If you insulate the interior wall, you should drywall & paint both sides & install a vapor retarder (kraft paper) to the warm side. This will limit vapor migration inside the wall, which will go from warm to cold.
Interesting. I've never heard of kraft paper as a vapour barrier - only poly. Must be regional differences. I agree that un-covered insulation is a bad idea. I would only insulate interior walls for sound.
lenaitch is offline   Reply With Quote
Old 02-12-2016, 03:28 AM   #17
Rewards Points: 400
http://www.greenbuildingadvisor.com/...vapor-barriers
Nik333 is online now   Reply With Quote
Old 02-12-2016, 08:55 AM   #18
Rewards Points: 459
Kraft paper is considered a "Vapor Retarder". Poly is pretty well impermeable, but kraft paper is designed to slow, but not stop vapor migration. Benefit being that, theoretically, water inside the wall structure could eventually dry through the retarder.
Selection or exclusion of vapor barriers and/or retarders is pretty important. The building science website that Nik333 linked to is a good source, but there are many other sources with great info. Depending on interpretation, though, some of them seem to contradict each other - newer seeming to supersede older, IMO.
http://energy.gov/energysaver/vapor-...sion-retarders
http://insulationinstitute.org/im-a-...isture-issues/
http://www.finehomebuilding.com/item...apor-retarders
http://www.energyvanguard.com/blog-b...-What-the-Heck
Nick DIY is offline   Reply With Quote
Old 02-12-2016, 08:58 AM   #19
Rewards Points: 459
Just realized that Nik333's link was to greenbuildingadvisor, not buildingscience. Same article I linked to actually. Oops.
Good info their, either way.
Old 02-12-2016, 09:28 AM   #20
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
Just kidding...!!
The Following 2 Users Say Thank You to Windows on Wash For This Useful Post:
Nick DIY (02-12-2016), Nik333 (02-14-2016)
Insulation question for vaulted home Talgonadia Insulation 3 08-22-2012 06:06 AM
?'s about foil-faced "bubble wrap" insulation badger73 Insulation 5 06-25-2012 05:09 AM
Several Insulation Quotes, Big Decisions to make knotquiteawake Insulation 2 05-04-2012 11:16 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
