Sofit Block For Blown In - Insulation - DIY Chatroom Home Improvement Forum
Old 11-09-2017, 07:34 AM   #1
Rewards Points: 438
Sofit Block for blown in
Hello folks,
I have yet another dumb question. I have blown in insulation that is held back by fiberglass batt (dam). However, as you can see from the circled area, there is some gap (day light) that may allow blown in to fall into sofit area.
Question is should 1) leave it be or 2) put some fiberglass to block this gap so blown in won't fall in. Also, can I have fiberglass touch small portion of the roof decking which I am reading isn't good. OR do I put baffle material to seal out this area from soffit - very difficult to do as the it's deep and dangerous with those nails from the roof deck
Many thanks in advance
sbkim is offline   Reply With Quote
Old 11-09-2017, 07:44 AM   #2
Rewards Points: 438
Wind washing?
"Installing foam blocks flush against existing attic baffles and sealing with foam gap sealant. Another is installing attic baffles/proper vents with a built-in wind barrier. Both of these methods ensure that the wind travels up the venting rather than into your house or the insulation.
Here is a link to a customer?s post-audit retrofit blog write up, where they installed foam blocking flush against the attic venting.
Old 11-09-2017, 10:29 AM   #3
Rewards Points: 438
Re: Sofit Block for blown in
I can't edit my original post but found this site which seems to indicate that perhaps sealing out the sofit with baffle is better:
https://www.ecotelligenthomes.com/bl...affled-baffles
Siding block install with electrical Daugela Electrical 14 12-20-2016 04:01 PM
Concrete (Cinder) Block Barebones Home : Seeking Advice granadaCoder Building & Construction 11 08-11-2012 07:03 AM
Rebuilding a cinder block wall Pawl Building & Construction 5 10-09-2011 09:46 PM
What to do with windows when firring out from a block wall. willemdejong Carpentry 1 06-04-2010 11:25 AM
Cracks In Block Wall Foundation vf100 Building & Construction 7 08-20-2008 09:48 PM
