Soffit Vents - Insulation - DIY Chatroom Home Improvement Forum
Old 03-07-2012, 11:01 AM   #1
jpc
jc
Rewards Points: 162
Send a message via Yahoo to jpc
Soffit vents
Hello everyone, just a question or two, about two weeks ago as some of you may remember my earlier posts, I blew insulation in my attic, all went well, but the other night I went up there to look around and noticed I may have gotten some in two maybe 3 of my soffit vents, now that the attic is full of insulation getting down in there would be a pain in the ???? u know, Would it be easier to get to from outside? how would i go about removing the soffit vinyl sheeting? Any insite or tips or advice is so much appreciated, Thanks in advance for any input
jc
jpc is offline   Reply With Quote
Old 03-07-2012, 12:31 PM   #2
Rewards Points: 1,188
can you blow it back out w/ a vacuum hose on the "out" side? if not, try sucking it through.
Old 03-07-2012, 12:40 PM   #3
jpc
jc
Rewards Points: 162
vacuming from inside the attic I couldnt due, i blocked everything under the rafter baffle, and hose wouldnt fit down there,But didnt even think about trying to blow it from the outside with my compressor,Ill try that as soon as i get off work, I didnt even think of doing that, I guess I over thought it, Thanks man , for your quick reply
Old 03-07-2012, 12:45 PM   #4
ok. I meant to try sucking it through the vent; don't know how wide the gaps are, but if it is cellulose it may sneak through easier than 'glass.
Vinyl Perf Soffit over Wood - No Vents nickelshine Roofing/Siding 18 05-29-2012 09:12 AM
Hidden Soffit Vents Mucluk Building & Construction 4 01-26-2012 08:15 AM
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing/Siding 1 09-07-2011 10:13 AM
Knee wall w/ soffit vents no ridge vent -- seal soffit vents? tblaz Roofing/Siding 1 04-24-2011 04:12 PM
Installing Soffit vents w/finished attic Nathan0115 Roofing/Siding 6 06-04-2010 09:05 PM
