Should I Insulate Ceiling In Well Room - Insulation - DIY Chatroom Home Improvement Forum
Old 02-17-2018, 09:33 AM   #1
Rewards Points: 264
Should I insulate Ceiling in Well Room
I live in MN and have a private well in my basement. I'm looking to insulate and clean it up, but I notice this cardboard type ceiling (see pics). Is this safe to remove and just glue up pink insulating foam-board? The ceiling is under the front concrete step. Thanks
Should I insulate Ceiling in Well Room-img_3583.jpg   Should I insulate Ceiling in Well Room-img_3587.jpg
arminius is offline   Reply With Quote
Old 02-17-2018, 10:22 AM   #2
JUSTA MEMBER
Rewards Points: 276
Re: Should I insulate Ceiling in Well Room
Pictures must be turned , I've never seen blocks used as a wall in the vertical alignment as you show.
You are loosing heat out the ceiling into the concrete steps, so insulating is a good idea, is that stuff loose and easily removed?
Seal every corner , seam, edge, everything. Heat escapes easy through the tiny cracks.
Can you say exactly what the "cardboard like" stuff is?
I have seen foam core , which is a thin foam lining with cardboard on both sides used, and always thought that it was better than nothing, but not too effective.
ED
de-nagorg is offline   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
arminius (02-18-2018)
Old 02-17-2018, 10:29 AM   #3
Rewards Points: 1,364
I don't know what that junk is. Perhaps there is no harm in going over it? Depends on what is behind it I guess. Yes foam insulation would be good. Code required it to be covered. OSB or drywall would work. I would hold it a half inch off of the block wall and run a bead of great stuff foam in the gap.
Marson is offline   Reply With Quote
The Following User Says Thank You to Marson For This Useful Post:
Tags
insulate basement , insulate ceiling
Insulating Ceiling of bungalow Master Brian Insulation 1 06-14-2016 05:26 PM
Lesson on how to give textured ceiling an even painted look stripedbass Drywall & Plaster 1 01-06-2016 10:16 PM
My add-on room in the back has 2x4 ceiling rafters! OffToAShakyStar Building & Construction 31 10-10-2011 11:21 AM
How to insulate a cold room valley boy Building & Construction 1 11-10-2009 09:50 AM
