Should I Add More Insulation To The Tunnel Of A Skylight? - Insulation - DIY Chatroom Home Improvement Forum
Old 01-01-2015, 10:22 PM   #1
Rewards Points: 14
Should I add more insulation to the tunnel of a skylight?
My skylight is forming condensation on the glass and it is dripping to the lowest corner and then making streaks on the drywall. I had the glass replaced since a carpenter said that was the problem. There is still condensation on the window that drips down and drips in my room. The roof ceiling around that lowest skylight side is all frosty and looks as if water iced it. If I put more insulation around the tunnel after the new glass was cauked and sealed in will this fix the problem? Do I need to insulate the roof ceiling around the skylight? I am hoping for any help, since it cost $500 just to replace the glass, which now apparently was not the problem.
nrwilson is offline   Reply With Quote
Old 01-02-2015, 12:39 AM   #2
Retired Moderator
Rewards Points: 7,174
Yes,Insulate it well---
I had a tall tunnel in a bathroom once---and installed an exhaust fan into it--that was severe--dumb design---
Sometimes--a sheet of clear plexiglass is installed to a tunnel ,at the ceiling--that acts like a storm window---and ends the condensation.
Old 01-02-2015, 10:59 AM   #3
Rewards Points: 14
Yes I had a piece of plexiglass there before the carpenter came and decided that I needed new glass and took it out. It still streaked down the drywall with it in then too. It was not sealed in there completely though because they just pulled it out easily. If I put it back in does it need to be sealed with caulk or what?
Old 01-02-2015, 12:09 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,946
The warm air rises. Any moisture in it will condense on the glass. It takes a really well insulated glass skylight to not have condensation.
What is the RH% in the house?
Insulation is always good. But, if you have a lot of moisture, creating layers is about the only way to fix it.
I've heard of some people have an exterior 'dome' they put over the skylight in the winter to create another layer so as to not have to deal with the plexiglass inside.
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
oh'mike (01-02-2015)
Old 01-02-2015, 04:58 PM   #5
Rewards Points: 14
So, how do I determine the relative humidity of the house, to see if it is a problem? The furnace has an aprilair and I run a dehumidifier in the basement during the fall to winter months. The tunnel is right in front of the main entrance that has a vented overhang that allows outside air to come in and hit the tunnel directly behind it. Does this have anything to do with increasing the condensation possibility?
Old 01-02-2015, 09:50 PM   #6
Registered User
Rewards Points: 526
Welcome to the forum!
Cold chute walls + warm house air = condensation. Either dehumidify or insulate the chute's walls/add house wrap, after air sealing in the attic.http://www.buildingscience.com/docum...bout-diffusion
Gary
PS. Yes, the lower glazing needs to be air-tight to work.
Old 01-02-2015, 09:59 PM   #7
Rewards Points: 14
If I put the plexiglass back how far away from the skylight is the best distance to try to stop the condensation? Does it need to be caulked or sealed somehow to make it air tight?
Also do I need any insulation on the roof around the tunnel or something else? It is icing up there on the roof coming off the lowest side from the skylight. Is this because of or from the condensation?
Old 01-02-2015, 10:01 PM   #8
Rewards Points: 14
Thanks for taking time to help a novice at attic repairs! Thanks for your input!
The Following User Says Thank You to nrwilson For This Useful Post:
Gary in WA (01-02-2015)
Old 01-02-2015, 10:15 PM   #9
Registered User
Rewards Points: 526
I'd add the p-glass at ceiling level BUT the chase will still be cold- even with tons of insulation without heat from the room. With the heat is moisture, from people, pets, cooking, showers, washer/dryers, etc. that has to go somewhere. Any pinhole (1/32") is enough to give moisture there. Rigid foam board makes a good air seal for the attic side, if accessible; http://www.finehomebuilding.com/desi...ght-shaft.aspx May also need to be covered with ignition barrier...
No added insulation ON the roof. Gary
Old 01-02-2015, 11:04 PM   #10
Rewards Points: 14
Wow what an education you just gave me with the two links you provided Gary! Thank you! Thank You!! 2 inch Rigid foam around the shaft since I am in zone 6 and the plexiglass on inside. Does anyone know of any qualified and reasonably priced people in Rock County in WI to complete this work?
Old 01-03-2015, 01:58 AM   #11
Retired Moderator
You want an insulation contractor--
Old 01-03-2015, 08:20 PM   #12
Registered User
Rewards Points: 526
You're welcome! 98% of the time, I get no response..... glad we could help.
Gary
Old 01-03-2015, 11:24 PM   #13
Rewards Points: 14
Thanks again for all the pointers from everyone! I really appreciate them! It gave me a solid starting point and direction to go! Thank you!
oh'mike (01-04-2015)
Existing blow in insulation vs new insulation - Keep or redo? Jaxx Insulation 9 01-17-2014 08:26 AM
Several Insulation Quotes, Big Decisions to make knotquiteawake Insulation 2 05-04-2012 11:16 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
Cold bathroom toeey1 Roofing/Siding 5 02-10-2010 07:29 PM
