Sealing Drafty Door Trim - Insulation - DIY Chatroom Home Improvement Forum
Old 02-11-2016, 07:15 PM   #1
Rewards Points: 776
Sealing drafty door trim
There's a decent sized gap (about 1/32") between the top header trim around my front door and the wall. When I put my hand up there I can feel cold air coming into the house.
The only caulk I have on hand at the moment is a DAP Alex Flex moulding/trim sealant (http://www.dap.com/dap-products-ph/a...-trim-sealant/).
Is this good enough to use to seal this gap around the trim and stop the cold air form coming in or should I use something else?
harpua728 is offline   Reply With Quote
Old 02-11-2016, 08:48 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 944
Cold air is from the outside wall. While sealing the gaps on the interior will help, the larger issue is the exterior sheathing, top plates, and other breaches in the envelope.
Need advice on brick cleaning / sealing & pavement projects mystiky Concrete, Stone & Masonry 3 08-06-2014 02:30 PM
Electrical outlet sealers versus draft sealing bluefoxicy Insulation 10 01-01-2014 09:55 PM
Looking for advice on Sealing Drafty Windows screamon demon Windows and Doors 3 11-07-2011 01:03 PM
Air sealing attic mmastran Insulation 11 05-25-2011 07:31 AM
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 06:36 PM
