Sealing Around Fan Vent Pipe - Insulation - DIY Chatroom Home Improvement Forum
Old 01-01-2020, 09:45 AM   #1
Rewards Points: 330
As the pictures show, I need to seal around this kitchen fan vent pipe. Insulation has fallen five feet down the opening which I will need to vacuum out.
Plan is to place drywall within 1/2" of the pipe to cover the opening, then spray foam (orange fire) the gap. Is this allowed?
Sealing Around Fan Vent Pipe-img_1889.jpg   Sealing Around Fan Vent Pipe-img_1888.jpg
Earnie is offline   Reply With Quote
Old 01-01-2020, 11:02 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 244
Re: Sealing Around Fan Vent Pipe
Yes, the pipe produces no heat like a chimney would. Sealing all around this protrusion is mandatory to keep fire at bay in the lower room, and to help with insulation.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
