Sealing Air Gap Around Front Door - Insulation - DIY Chatroom Home Improvement Forum
Old 02-05-2016, 01:22 PM   #1
Rewards Points: 40
Sealing air gap around front door
Our recently moved-into home has an air gap around the front door. I'm crusading to stop wasting water (Southern California, here) and gas for heat, so I would like some advice on how best to insulate the gap.
How should this be done? Metal strips? gray rubbery strip on the face of the contact surrounding the door?
Thanks.
WestofLongBeach is offline   Reply With Quote
Old 02-05-2016, 02:00 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 904
Bronze fin weatherstripping will work better here.
Old 02-05-2016, 02:05 PM   #3
Rewards Points: 1,880
#1, Make sure the door is closing tight to the stop molding. The tab inside the latch plate may need to be bent some to hold it tighter.
Open the door and take another picture so we can see the stop molding.
If this is an older house and this is a wooden door any Lowes or HD sells a simple to install three piece kit with aluminum strips with built in rubber seals.
Old 02-06-2016, 11:16 AM   #4
Rewards Points: 40
OK, here are two pictures of the doorjamb. The stop molding is ~3/8".
Sealing air gap around front door-door2.jpg   Sealing air gap around front door-door-3.jpg
Window popped out in traffic! Bigplanz Automotive Repairs 12 06-27-2015 06:35 PM
Replacing Prehung Front Entry Door in Stucco a1481155 Windows and Doors 13 09-04-2013 05:11 PM
Sidelight replacement on front door. jeffdoesrepairs Windows and Doors 8 06-29-2013 09:01 AM
What color would you paint Garage Door, Front Door, Shutters, Porch Columns Nikki91298 Painting 11 06-21-2013 03:58 AM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 07:22 AM
