Sealed Air Gap Vs Solid Material - Insulation - DIY Chatroom Home Improvement Forum
Old 12-30-2016, 10:02 AM   #1
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 714
Sealed Air Gap vs Solid Material
I'm planning on building a smoker and to insulate it, I was going to build an outer shell that would leave a 2" gap all around the smoker. That gap would be sealed off (but not under vacuum). Would it be better to leave the 2" gap sealed with only air inside or would stuffing it with insulation be better?
WirelessG is offline   Reply With Quote
Acrylic Solid Stain vs Oil Semi Trans or Semi solid torxx Painting 19 10-03-2012 08:37 AM
Replacing underlayment in entire house...what material to use? Dave321 Flooring 23 12-23-2011 02:38 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 07:41 PM
