Roxul Vapor Barrier - Insulation - DIY Chatroom Home Improvement Forum
Old 02-06-2016, 09:37 PM   #1
Rewards Points: 225
Roxul vapor barrier
Does this insulation need a vapor barrier? Exterior wall 2x4 wall. Read conflicting reports. Some say yes others say no. Which is it? Thanks.
gt1935 is offline   Reply With Quote
Old 02-06-2016, 10:52 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 808
Roxul is not a vapor barrier in this case. Depending on applications end where you live, you may need to add one.
Roxul Insulation premington Insulation 14 02-27-2015 12:27 PM
Floor insulation, Roxul vs closed foam Arky217 Building & Construction 1 05-10-2014 11:05 PM
Moisture between foam board and Roxul gma2rjc Insulation 12 01-30-2014 12:45 AM
Roxul; just my assessment jklingel Insulation 4 01-20-2013 09:32 AM
Is my Roxul sound insulation toxic? Brit Insulation 20 08-12-2012 09:13 PM
