Is Roxul Safe And Sound Worth The Price?! - Insulation - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 2 Post By Bud9051
  • 1 Post By 3onthetree
  • 1 Post By NickTheGreat
  • 1 Post By chandler48
Old 04-02-2019, 01:19 PM   #1
Rewards Points: 44
Is Roxul Safe and Sound Worth the price?!
So I'm finished running all of the electrical in my music room so I'm looking to put up some insulation. I saw a lot of people mentioned and talked about Roxul Safe and Sound but is it really worth the hefty price tag? I saw a couple of other videos that say no and that any insulation is better than nothing and the gains of Roxul vs standard insulation is minimum.
Do any of you guys have input or first hand testing comparison etc for Roxul vs other products. My room is a 14x30 room so price wise it will make a huge difference.
spaz is offline   Reply With Quote
Old 04-02-2019, 02:52 PM   #2
Mike Milam's Avatar
Rewards Points: 96
Re: Is Roxul Safe and Sound Worth the price?!
I can't give a real comparison because in the past I used regular insulation (R13) in my last basement finishing and found it of little good. I used Ruxol in my current basement and except for the bass sound, you don't hear anything upstairs unless it is nearly turned all the way up.
Thank a police officer for being the one who runs 'TO' a report of shots fired, while everyone else runs 'AWAY'
Mike Milam is online now   Reply With Quote
Old 04-02-2019, 03:20 PM   #3
Rewards Points: 270
Hi Spaz, I'm not familiar with where and why you want to use it. Looking for insulation performance or sound reduction??
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 04-02-2019, 03:21 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 6
Ayuh,..... For many reasons, I'm a rock wool believer, sound included,.....
Sprayed close-cell is too expensive at times, but an alternative, if money is no object,....
Old 04-02-2019, 03:22 PM   #5
Rewards Points: 44
Bud
Hey Bud,
Basically in a nut shell I'm building a 14x30 music room. I'll have several drumsets and my band practices here. I'm looking to get some sound reduction and keep some heat in the basement room since I don't have any vents down there also during the winter.
Old 04-02-2019, 03:31 PM   #6
Rewards Points: 270
In a basement sound issues are usually "up" while insulation is to the sides. Air seal the rim extremely well as a lot of cold air finds a way through.
If you are using drywall on the ceilings the resilient channels can help decouple the sound from the floor joists. Roxul is very dense and can absorb some of the energy as well.
Eliminating sound transmission often involves finding the easy paths where most noise travels. Forced hot air heating ducts can bypass the best sound deadening efforts.
Bud
Bondo and Mike Milam like this.
Old 04-02-2019, 04:15 PM   #7
Hammered Thumb
Rewards Points: 152
I didn't continue following your other posts so I don't know what you're doing on the ceiling and such. But I'd say back of napkin calc mineral wool batts would be worth the $$. The density of objects the waves go through is one way to alter them. I have used fiberglass batts as a cheap alternative in the past and will always now spend the money for mineral wool. I'm wiser now.
You sure are going to be sweating a lot in there and the humidity, man. Especially if you jump a lot a'la David Lee Roth style.
Bondo likes this.
3onthetree is offline   Reply With Quote
Old 04-03-2019, 07:27 AM   #8
Rewards Points: 4,864
Value is something only the buyer can decide. I have a music room with a drum set, piano and several guitars and I leave the door open so no insulation would be worth it to me since I don't have a concern about the noise level.
stick\shift is offline   Reply With Quote
Old 04-03-2019, 10:25 AM   #9
Rewards Points: 44
I have a 3yr old and a baby on the way to be born mid May.
So I would like to keep practicing and playing and try not to drive my family nuts. So there is a concern for noise level for me unfortunately.
Back in the day before the dad life, no concerns lol I miss those days
Old 04-03-2019, 10:51 AM   #10
Knows Enough to be Danger
Rewards Points: 1,295
It's good stuff, but not a magic bullet you can just slap in and stop all noise.
To do it right, like they do in the home theater world, it takes a bit of work. Multiple layers of drywall, decoupled from the structure. The ultimate solution would be to build "a room within a room" to stop all sound vibration from escaping.
I have saved a few articles that are very informative
https://www.soundproofingcompany.com...vel-1-solution
https://www.soundproofingcompany.com...proofing-walls
Mike Milam likes this.
NickTheGreat is offline   Reply With Quote
Old 04-04-2019, 05:25 AM   #11
Naildriver
chandler48's Avatar
Rewards Points: 438
I remember back in the 60's, our high school band practice rooms were almost sound proof. All the walls were at different angles so the sound had no place to reverberate and it died instantly. It was a weird feeling, but effective. I agree, decoupling the walls and ceiling are about the only way to achieve sound reduction to a great degree. Roxul is an excellent insulation and sound reduction product, giving R15 in the same space that fiberglas only gives R13.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Tags
music room , roxul , sound insulation
Is this sound and safe for power to a shed? Grinder_1 Electrical 38 09-13-2017 05:26 PM
Insulating basement ceiling from sound, not heat loss? Kory Beam Insulation 9 07-27-2017 09:24 PM
Sound Barrier: Roxul Safe n Sound (Lowes) vs dB-3 Acoustical Barrier (Home Depot) Quackerjack Insulation 6 02-26-2014 01:54 PM
Is my Roxul sound insulation toxic? Brit Insulation 20 08-12-2012 09:13 PM
Header Insulation TheMadADDer Building & Construction 4 02-22-2011 01:47 AM
