Roofmate Rigid Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 07-24-2016, 02:32 AM   #1
Rewards Points: 2
roofmate rigid insulation
hi can you use roofmate rigid insulation around a garage slab below the ground? does it hold moisture?
ksbs2007 is offline   Reply With Quote
Old 07-29-2016, 03:16 PM   #2
Registered User
Rewards Points: 526
Re: roofmate rigid insulation
------------Welcome to the forums!-------------
Yes, I'd use it; https://www.google.com/search?q=roof...utf-8&oe=utf-8
Gary
Crawlspace Insulation with Rigid Foam Board HDS Insulation 1 12-04-2014 07:42 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Polystrene (DOW) Rigid Insulation board - fireproof AndrewF Building & Construction 8 11-28-2010 01:17 PM
Covering rigid foam insulation in furnace area looking4ideas Building & Construction 4 12-30-2009 05:49 AM
Using rigid foil faced foam insulation Ronnie1a Remodeling 1 01-22-2008 01:23 PM
