Roof Letting In Heat - Insulation - DIY Chatroom Home Improvement Forum
Old 06-10-2014, 10:42 AM   #1
Roof letting in heat
Is there any flooring I could put up on my roof patio that would absorb some the heat so that it doesn't transfer down into my bedroom directly below it? The roof is flat and a patio. It is in direct sunlight most days.
Seabrook is offline   Reply With Quote
Old 06-15-2014, 12:13 PM   #2
Rewards Points: 455
YEah, put some of that reflective tin foil barrior stuff up
http://www.atticfoil.com/install-que...t-vs-foil.html
Cletis is offline   Reply With Quote
Old 06-17-2014, 04:01 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 718
I take it that this is a flat roof? What type of ceiling insulation do you have?
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 06-18-2014, 07:44 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 944
Pictures are going to help here.
Old 06-20-2014, 12:49 AM   #5
Following, thanks
Jerven is offline   Reply With Quote
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 09:00 PM
Are you ready for SNOW & ICE ? Roofmaster417 Roofing/Siding 15 10-09-2011 09:25 AM
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 12:56 AM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 12:19 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
