Rim Joist Insulation? - Insulation - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By Windows on Wash
  • 3 Post By Dave Sal
Old 12-10-2016, 11:48 AM   #1
Rewards Points: 155
rim joist insulation?
my basement concrete wall is around 60f, but the rim joist area/header is around 50f. the rim already has fiberglass bat, so i'm not sure i need redo the insulation or not. outside is around 32f
s002wjh is offline   Reply With Quote
Old 12-10-2016, 04:37 PM   #2
Rewards Points: 1,916
Re: rim joist insulation?
There has to be at least few hundred post on this one subject.
Tried the search funtion?
Fiberglass does not block air floor and will just end up causing mold.
Need 2" foam and spray expanding foam to seal the gaps.
Old 12-10-2016, 04:48 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,046
Good read.
https://buildingscience.com/document...m-at-rim-joist
Crazyjake8493 likes this.
Old 12-10-2016, 07:04 PM   #4
Rewards Points: 155
ok what rigid foam/board i should use on rim joist. also what caulk i can use on the seam/gap of board.
Old 12-11-2016, 12:06 PM   #5
Dave Sal's Avatar
Rewards Points: 32
I used Owens Corning R10 rigid foam board. Was about $18 per 4'x8' sheet about 5 years ago. I think I used silicone caulk to seal the edges (the attached pic doesn't show the silicone sealing of the edges). In addition to insulating the rim joists I closed off and sealed the two outside air vents. The crawlspace now stays about 63 degrees all year long. It used to get close to freezing during the winter.
Dave Sal is offline   Reply With Quote
Rim Joist insulation options? learmoia Insulation 4 10-11-2012 12:02 AM
Floor joist insulation help Drewkernovich Insulation 3 01-05-2012 09:50 AM
insulation of rim joist sherryne Building & Construction 1 01-04-2011 12:12 PM
Floor joist insulation Arky217 Building & Construction 0 12-29-2010 11:56 AM
Rim Joist Insulation ja191992stg Building & Construction 53 03-22-2010 08:41 PM
