Rim Joist Insulation With 2" Rigid Pink Foam - Insulation - DIY Chatroom Home Improvement Forum
Old 01-30-2016, 09:21 AM   #1
Rewards Points: 1,400
Rim joist insulation with 2" rigid pink foam
I would like to insulate my rim joist with 2" pink foam
I'm planning to proceed as follow
1) caulk the perimeter of the cavities
2) cut the pink foam to leave a gap all around (gap = size of the foam spray nozzle)
3) Put some caulk on the back of the piece of foam to make it stick to the rim joist, making sure I have my gap all around
4) Put spray foam insulation by inserting the nozzle of the can inside that gap
What do you think?
About the spray foam, should I use the regular Great Stuff, or the window foam that expand less?
french_guy is offline   Reply With Quote
Old 01-30-2016, 10:00 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
The gap is just to make it easy to get the foam in place. You don't have to purposefully leave a gap if the rims are consistent in size. You can butter the openings with sealant and then just caulk the edges as well.
Use the window and door foam (closed cell variant) if you are going to foam them in place.
Either way, your plan looks solid.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Dave Sal (02-13-2016)
Old 01-30-2016, 10:36 AM   #3
Rewards Points: 166
If you are good at cutting, a press fit ends up being a lot faster. Where the foam likes a larger gap, using a caulk at the seams does well.
Check local codes to see if they will require the pink to be covered with an ignition barrier, like 1'2" drywall.
Bud
Bud9051 is online now   Reply With Quote
Old 01-30-2016, 10:44 AM   #4
Save some bucks and use the the "2 component spray system" they sell at HD and Lowes. It will cut your costs, rather then buying all the cans of "great stuff". Just make a little dolly to pull around the 2 propane like canisters.
Soup
campbell804 is offline   Reply With Quote
Old 01-30-2016, 10:57 AM   #5
Rewards Points: 906
Originally Posted by campbell804
Save some bucks and use the the "2 component spray system" they sell at HD and Lowes. It will cut your costs, rather then buying all the cans of "great stuff". Just make a little dolly to pull around the 2 propane like canisters. Soup
It will definitely save you time. Not sure about the money part.
Old 01-30-2016, 11:45 AM   #6
I don't mind the time.....I can do a few cavities here and there
I think the 2 can spray mix is messy
I will try the press fit and see if it's not too difficult to put it into the cavity
If too difficult, I guess I will go with my original plan
Old 01-30-2016, 04:17 PM   #7
Rewards Points: 16
Foam on Rim Joist
The 2" will be a good start, sealing the edges, but be sure to run a bead along the top plate at the concrete as well. Rather than tanks, I bought larger cans that thread onto a gun. Far nicer to be able to shut off as well as having an accurate reach with a 12" tip. Put lotion on hands prior, even if wearing good gloves, faster cleanup... and be ready to write off any clothes you wear because the foam sticks to everything. Foam gives off a toxic smoke so as noted above if your code requires or not, it is best to drywall over it. I ran Roxul on top which is also fire resistant, to exceed R20.
sbryant324 is offline   Reply With Quote
Old 01-30-2016, 05:38 PM   #8
I've done 3 cavities relatively quickly (2 large - 34 x 9 and 1 small - 6 x 9)
The foam cuts very well on my table saw...
I cut the foam as tight as possible. I caulked 1st the perimeter of the cavities, then install the foam and sealed with caulk again. Actually, I haven't used the spray foam....Is this OK?
Rim joist insulation with 2" rigid pink foam-img_1280.jpg   Rim joist insulation with 2" rigid pink foam-img_1281.jpg   Rim joist insulation with 2" rigid pink foam-img_1282.jpg   Rim joist insulation with 2" rigid pink foam-img_1283.jpg
The Following User Says Thank You to french_guy For This Useful Post:
Windows on Wash (01-30-2016)
Old 01-30-2016, 09:11 PM   #9
Rewards Points: 166
That looks perfect, when are you coming over for my job . Can foam needs the gap idea you started with, but caulking does not and the caulking is much more forgiving when fingers are required.
A+
Bud
I do have a question for you, are you cutting that 2" in one pass with your table saw and if so what blade are you using. I have to cut 1" deep and flip it to avoid the blade grabbing the foam.
I have a small battery powered circular saw which runs at a much lower speed and it works great on foam, doesn't melt. Been wondering if I could slow my table saw down.
Old 01-31-2016, 07:22 AM   #10
Thumbs down
"A+" sounds................French
Yes, I cut the 2" thick foam in 1 pass
I'm using that blade:
http://www.amazon.com/gp/product/B00...ilpage_o03_s00
Mounted on a basic Ryobi table:
http://www.homedepot.com/p/Ryobi-15-...S10G/205216309
Cuts are very good (at least for my taste) and the foam is not melting at all
I will do more cavities today, but will post pictures because I have deep ones going under a bay window (cantilever?). For now, there is some fiber glass, lay loose and randomly. Not sure what is the best way to proceed in that case.....!
Old 01-31-2016, 07:50 AM   #11
Rewards Points: 312
I would be leaving one to be removed on a cold ass winter day to check for rim joist condensation / moisture. In the 3rd picture of reply #8 there is an indication of previous moisture on the bottom edges of the joist.
Old 01-31-2016, 07:59 AM   #12
Yeah, I saw it.....The previous insulation was fiber glass only, and it was kind of darkened in some places (condensation issue I guess?)
However my basement is not finished....
When I installed the foam, it was such a tight fit that even without the caulk, removing the board would mean breaking it !!!
Old 01-31-2016, 08:15 AM   #13
Rewards Points: 166
Fiberglass insulation would have allowed warm air to pass through it to reach the cold rim joist and form condensation. If a fiber material is used it must be well air sealed and depending upon the climate possibly vapor sealed. But air is the primary transporter of moisture vapor.
I use a similar blade to the one you linked, but my rigid is the blue type. I haven't yet tried that rose colored and I'm not sure if it is formulated differently or not. I will be buying more so will try some. I'll get a new blade as well as this one is now coated with residue.
Thanks,
Bud
Old 01-31-2016, 08:21 AM   #14
WhatRnsdownhill's Avatar
Rewards Points: 2,220
thats some nice n neat work....
WhatRnsdownhill is offline   Reply With Quote
Old 01-31-2016, 08:36 AM   #15
Rewards Points: 906
Looks very clean.
As Bud mentioned earlier, I would look at covering it with a ignition/fire barrier like fibrous insulation or drywall.
Basement rigid foam insulation aadepa Insulation 2 12-17-2014 09:39 PM
Crawlspace Insulation with Rigid Foam Board HDS Insulation 1 12-04-2014 07:42 PM
Grade on slab, 2" Foam Insulation - XPS, Required 3" termite inspection gap??? rmtbrown01 Building & Construction 0 10-19-2011 03:08 AM
Polyisocyanurate Rigid Foam Insulation Boards Over Plywood Sheathing & Vapor Barriers cloves Building & Construction 10 12-05-2010 11:31 AM
rigid foam insulation ctkeebler Building & Construction 24 11-09-2009 06:49 PM
