Rim Joist Insulating - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By davidmr
Old 09-15-2016, 09:07 AM   #1
Young Bachelor
CTSNicholas's Avatar
Rewards Points: 481
Would you guys use Mineral Wool (rock fiber) insulation or XPS rigid foam to insulate the rim joists to reduce noise when rain/hail hits the siding? Right now the basement is awful loud during a storm. I have mineral wool insulation, but I fear moisture may be an issue if not done properly whereas XPS rigid foam glued to the rim joist seems pretty idiot proof, however, maybe not as good at reducing noise?
CTSNicholas is offline   Reply With Quote
Old 09-16-2016, 12:15 PM   #2
Rewards Points: 84
Re: Rim Joist Insulating
2" of xps is your best choice.
You can always put mineral wool over it.
stick\shift likes this.
davidmr is offline   Reply With Quote
Old 09-16-2016, 02:03 PM   #3
Young Bachelor
Rewards Points: 481
I was leaning towards the foam. It seems to reduce some noise. I'll probably just double or triple layer it to achieve more sound deadening.
Any of you guys find a convenient way to insulate the basement wall with foam, but wrap the corner where the sill plate sits? I'm thinking I will just form a little boxed top with XPS to seal off that exposed concrete and sill plate. Depends on how much I insulate the rim joist, I suppose.
Insulating Basement Wall - Sill Plate / Rim Joist maurzy01 Insulation 13 03-13-2015 11:33 PM
Rim joist insulating issue diyGK Insulation 19 01-12-2015 08:14 PM
Insulating Recessed Rim Joist matt151617 Insulation 4 09-03-2012 08:28 PM
notched out joist ? problem ? cvcman Building & Construction 13 05-24-2012 08:21 PM
Insulating rim joist bseries4life Insulation 5 04-01-2012 10:11 PM
