Rigid XPS + Pipes, Electical And Great Stuff? - Insulation - DIY Chatroom Home Improvement Forum
Old 09-02-2015, 04:45 PM   #1
Rewards Points: 31
Rigid XPS + Pipes, electical and Great Stuff?
I am finishing my basement and before doing so I wanted to get some Rigid Extruded Polystyrene on the walls.
I have several places where there is plumbing (1/2" copper) strapped to the wall, as well as some electrical. Based on my searches, it sounds like it should be fine to get the XPS tight to the copper, wrap in split foam, and finish the voids off with Great Stuff. Please, correct me if I am wrong...
As for the electrical, there is a grounding wire stapled to a 2x4 that is screwed to the wall... I am thinking leaving an old 2x4 sandwiched between the foundation wall and a combination of Great Stuff and XPS is a bad idea. I also have a 120V doing something similar.
But maybe I am wrong and it is perfectly fine to leave this stuff in behind and forget about it... I would actually love to be wrong about it, as it would save me from having to rip the lumber off and re-attach the electrical...
Rigid XPS + Pipes, electical and Great Stuff?-img_4213.jpg   Rigid XPS + Pipes, electical and Great Stuff?-img_4211.jpg
domh is offline   Reply With Quote
Old 09-02-2015, 11:04 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 856
It should be fine but keep in mind that any insulation that you put up on warmside wall will keep that interstitial space from getting warmed up and therefore colder and more subject to freezing.
The Following 2 Users Say Thank You to Windows on Wash For This Useful Post:
domh (09-21-2015), Yodaman (09-07-2015)
Old 09-05-2015, 08:03 PM   #3
Registered User
Rewards Points: 526
No, you could easily have future problems.
"I have several places where there is plumbing (1/2" copper) strapped to the wall, as well as some electrical. Based on my searches, it sounds like it should be fine to get the XPS tight to the copper, wrap in split foam, and finish the voids off with Great Stuff. Please, correct me if I am wrong...' ----- once you cut off the basement heat from the supply lines, they will/are conducting cold from the CMU's. With the new insulation -insulating- them from the heated side, they could easily freeze, especially at the above-grade portions of wall. With insulation/drywall in front of them, the dew-point temperature will be lowered to condense moisture more easily. depending on local conditions, the wood 2x4 will stay wet during the winter months and into summer before drying, due to new drywall/insulation. Best to put them in a frame wall or under furring, in front of required thickness of XPS to stop condensation per location for your basement; http://energycode.pnl.gov/EnergyCodeReqs/index.jsp
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
domh (09-21-2015)
Old 09-05-2015, 08:42 PM   #4
Rewards Points: 856
He did say he would be wrapping them with split foam and then spraying them. I am assuming, perhaps foolishly, that the wrap will be all the way around. If you are just trying to clamshell it from the front and the wall side will be uninsulated, all the disastrous stuff that Gary mentioned would happen.
Where is the house again?
Old 09-05-2015, 09:46 PM   #5
Registered User
Rewards Points: 526
Toronto...
Maybe I understood it wrong...
"fine to get the XPS tight to the copper, wrap in split foam"--- not tight to the split foam.
Gary
Old 09-05-2015, 10:02 PM   #6
Rewards Points: 856
Originally Posted by Gary in WA View Post
Toronto...
Gary
How did you figure out he is in Toronto? Did I miss that somewhere?
Hopefully the poster is still around to clarify his plan.
Old 09-07-2015, 07:03 PM   #7
Registered User
Rewards Points: 526
Lol; http://www.diychatroom.com/f5/ditra-...ayment-138266/
Gary
Old 09-07-2015, 08:01 PM   #8
Rewards Points: 856
Holy smokes...2012. I am guessing you searched that vs. remembered it.
Old 09-11-2015, 02:08 PM   #9
Rewards Points: 31
Wow, thanks for the responses, guys. I have been on vacation and missed the replies.
Good sleuthing... Indeed, I am in Toronto. As for clamshelling the pipes, nope I would definitely make sure to get the foam pipe wrap all the way around with the split facing the warm side.
Very little of the basement is above grade. It's almost entirely below. It is actually very temperate (nice and cool in summer and maintains a comfortable temperature in. winter, even if the heat is turned off).
But even still, if I insulate the pipes but leave them where they are, they are going to be pretty snug against the CMU. And since I am using 2" XPS, that leaves them much close to the CMU than the warm side...
For the amount of work required to move the network of pipes over and get the electrical moved (heck there'll be a new framed wall anyway) I might as well just do it. As for XPS insulation, I'm going to be posting something shortly begging for advice haha.
Old 09-11-2015, 04:02 PM   #10
Rewards Points: 856
Unless you get those things insulated, inside 2 inches of XPS foam, they're going to get mighty, mighty cold
The Following User Says Thank You to Windows on Wash For This Useful Post:
domh (09-21-2015)
Old 09-11-2015, 05:47 PM   #11
Rewards Points: 31
Oh, for sure. There's no way they're NOT getting insulated. It's more a matter of whether or not I can keep them INSIDE the 2" of insulation, as opposed to have to move them into the framed space (between the drywall and XPS).
The Following User Says Thank You to domh For This Useful Post:
Windows on Wash (09-11-2015)
Old 09-21-2015, 02:34 PM   #12
Rewards Points: 31
Pipes and electrical all moved now. Next stop: insulation town. Thanks again fellas!
Windows on Wash (09-21-2015)
Old 09-23-2015, 11:48 PM   #13
Registered User
Rewards Points: 526
You're welcome, we appreciate the business!
Be sure to use unfaced XPS on the walls so as not to drive the moisture to the mud sill for rot there, or scaling on the concrete at the minimal area above-grade as you said. Use foil-faced on the wood rims to prevent summertime moisture at rim/board interface. Caulk/seal the wood joints (plate-joist-rim) before board ins. to prevent air infiltration between those. check with us on installing boards...
Gary
Old 09-26-2015, 12:03 PM   #14
Rewards Points: 31
Gary
Well, here's the thing... the house is cinderblock/masonry wall atop the foundation (it was built in '67). So while I do have rim joists, they are actually flush in some places or extending a bit into the basement interior in others. I am pretty sure I can spray foam in the gaps, but since the rim joists have the masonry separating them from the exterior, is it necessary to use foil-faced?
The reason I ask is because my boards are 96". The height from the floor to the top of the rim joists is 96-3/4"... Would it be acceptable in this case to simply use the full length of the board and then spray foam the remaining gap?
Pics attached. Thanks for your advice!
Rigid XPS + Pipes, electical and Great Stuff?-img_6098.jpg   Rigid XPS + Pipes, electical and Great Stuff?-img_6099.jpg   Rigid XPS + Pipes, electical and Great Stuff?-img_6102.jpg
Old 09-26-2015, 01:45 PM   #15
Rewards Points: 856
Yes on the board length. Most are left a bit short and then foamed at the top anyway.
Tags
basement , insulation , xps
