Rigid Foamboard For Insulating Between Rafters - Insulation - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 3 Post By chandler48
Old 07-21-2018, 12:41 PM   #1
Rewards Points: 2
Are air baffles requited if installing 2" rigid foam between 2X4 rafters?
jrharr1@gmail is offline   Reply With Quote
Old 07-21-2018, 02:02 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 476
Re: Rigid Foamboard For Insulating Between Rafters
Is this an attic? Normally rafters are not insulated, but the ceiling joist bays are. Attic temperatures are to remain as close to outside temperature as possible. Is this in a house or a garage/shop building? Pictures always help.
joecaption, stick\shift and Nealtw like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 07-21-2018, 06:43 PM   #3
Rewards Points: 1,918
A few other questions in addition to Chandlers great questions, what's your location?
Main reason I ask is just R10 of insulation is not likely to be enough.
https://www.energystar.gov/index.cfm...sulation_table
Old 07-23-2018, 07:59 PM   #4
Rewards Points: 12
I think it depends on the type of roofing you built for your home? If it is metal then you need foam insulation with aluminum
EarthwoolAU is offline   Reply With Quote
Rigid foam in walls? Master Brian Insulation 6 06-06-2018 09:30 PM
Integrity of roof rafters williams_run Roofing/Siding 4 06-10-2015 06:41 PM
Half vaulted ceiling with 2x6 rafters on 16 OC vestaviascott Building & Construction 9 04-21-2015 08:28 AM
Rigid foamboard in attic insulation? strategery Insulation 11 10-07-2014 02:26 PM
Insulating 2x4 attic ceiling rafters help needed tseverson Insulation 2 11-01-2011 07:57 PM
