Rigid Foam Or Polly For Basement Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 08-05-2018, 07:54 PM   #1
Rewards Points: 88
Rigid Foam or Polly for basement insulation
I live in a climate where in the winter it gets to -40C one day and 0C the next day. I am insulating my basement and I have heard some people say:
concrete --->rigid foam ----> studs ----> bat insulation between studs---->vapour barrier
Others say
concrete---->polly----> studs ----> bat insulation between studs---->vapour barrier
Any ideas on what should be done?
RTibs is offline   Reply With Quote
Old 08-05-2018, 08:12 PM   #2
retired framer
Rewards Points: 890
Re: Rigid Foam or Polly for basement insulation
Foam taped and sealed is a vapour barrier and you only want one.
Old 08-05-2018, 08:28 PM   #3
Rewards Points: 88
Ok good to know, thanks!
What are the pros and cons to each approach, polly vs. rigid foam?
Old 08-05-2018, 08:47 PM   #4
retired framer
Rewards Points: 890
I don't if there is one. you just don't want warm moist air coming in contact with cold surface.
Old 08-08-2018, 11:55 AM   #5
Rewards Points: 460
My city actually specifies no vapor barrier in the basement so check with your local codes in case yours is similar.
I did rockwool in my basement because it is impervious to water. I then spray foamed the top plate for fire stopping. My local codes stated that every 10 feet I have a fire block in the horizontal direction so I did at least that much.
Sdiver2489 is offline   Reply With Quote
Insulating Basement w/ Rigid Foam and Batt Reilley Building & Construction 4 08-03-2013 10:07 PM
Tile over rigid insulation. Tas25 Building & Construction 7 10-16-2011 06:46 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
rigid foam insulation in walls gossamer Building & Construction 12 02-03-2009 09:26 PM
Rigid foam as floor insulation rkhpapa Building & Construction 3 09-24-2006 06:06 PM
