Retrofitting Attic Baffles - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree2Likes
Old 04-14-2018, 09:35 PM   #16
retired framer
Rewards Points: 282
Re: Retrofitting attic baffles
Originally Posted by Bud9051 View Post
Argh! I'm not a member and just clicked and it went right through. Don't know what the difference is. Too big of an article to post here so will check for another source.
Bud
If anything can go wrong it will go wrong for me, just my lot in life.
Old 04-16-2018, 09:20 PM   #17
Originally Posted by brendelac View Post
Has anyone tried making their own ridgid baffles (wood or otherwise) to retrofit in an already insulated attic? I tried the styrofoam baffles, but they get torn up on the roofing nails and I have to get so close to the soffits to be able to feed them through that I am basically face-down in the insulation with the roof (and nails) centimeters from the back of my head. If I were to make my own baffles, I'm hoping to be able to use a push stick to avoid the above unpleasantness.
My soffits are plywood and I was initially thinking about removing them and then installing the styrofoam baffles from the outside and then installing perforated soffits, but I think that I have enough venting in the current soffits so if I can leave them in place, I think that would be the easiest route.
Thoughts or suggestions? Thanks.
I did it and it was pretty easy. I used the black plastic baffles from Lowe’s. I bought the thinnest fence picket they had and used that to press the insulation down. Surprisingly, the roofing nails didn’t give me too much trouble. I used 1/4 inch staples to secure them. On the sections with the highest ceilings, I had to use a baffle and a half, which required me to reach down into the cavity to staple where they overlap. It was kind of tricky.
Bud9051 and Nealtw like this.
LEDlighting is offline   Reply With Quote
Attic ridge vent - use of baffles or fanfold insulation nilanjan Roofing/Siding 6 02-14-2018 01:28 PM
Baffles / Rafter / Ceiling Vents Needed? Garage Attic tk5 Insulation 5 08-27-2017 11:14 PM
Ideas for retrofitting baffles/insulation in vaulted ceiling of built out attic room rachelsue20 Insulation 5 04-28-2012 07:49 PM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
