Replacing Walls With Existing Blow-in Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 07-24-2018, 10:50 PM   #1
Rewards Points: 18
Replacing walls with existing blow-in insulation
I'm replacing the existing exterior walls which are made of paneling, with drywall. Behind the paneling is blown-in insulation. Although much of it remains, quite a bit of the blown-in insulation has fallen out. Instead of trying to salvage any of it, should I just remove this and replace it with fiberglass bats?
HolyCow is offline   Reply With Quote
Old 07-31-2018, 12:31 AM   #2
Rewards Points: 12
Re: Replacing walls with existing blow-in insulation
any image you can share mate? If I think it is more logical to just replace the entire thing than salvaging the blow in insulation
EarthwoolAU is offline   Reply With Quote
Old 07-31-2018, 05:37 AM   #3
Rewards Points: 166
Hi HC, more details on what you are doing would help. Salvaging blown-in insulation from the walls would be difficult coming out and going back in, not an option IMO. Plus, once the walls are empty you can address air sealing which is now known as a high priority.
What is on the exterior, sheathing, boards, and siding. And how old is the house.
Bud
Bud9051 is offline   Reply With Quote
Tags
blown-in , insulation
Blow-in insulation - exterior walls kaver22 Insulation 2 05-24-2017 07:47 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-19-2011 11:31 PM
Exterior walls need upgrade in insulation xjsparky Insulation 7 06-22-2011 08:43 PM
Blow in insulation Iowabucks General DIY Discussions 1 10-09-2007 08:20 AM
