Replaced Weatherstripping, But There's Still Light Coming Through - What's Next? - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Dubau2
Old 01-27-2019, 01:40 PM   #1
Rewards Points: 8
Replaced weatherstripping, but there's still light coming through - what's next?
I replaced the weather stripping on my front door for the first time in probably decades. I could actually see light coming through. Taking the old stuff out and putting the new stuff in was pretty trivial. However, there is still light getting through the crack. What's the next step to insulating the door?
Here's an album showing the light getting through the door and the new weather stripping that I put in:
https://photos.app.goo.gl/4ZxfNPE8m4CGMF8JA
Thanks for your help!
billNC is offline   Reply With Quote
Old 01-27-2019, 01:58 PM   #2
Rewards Points: 124
Re: Replaced weatherstripping, but there's still light coming through - what's next?
Hi Bill,
Just saying Hi as I don't do well with doors. The ones I have had to seal have all involved getting the door and frame to close uniformly then deal with the seal.
I'll watch from the sidelines.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
Old 01-27-2019, 02:32 PM   #3
Rewards Points: 66
Hi, Bill,
When standing on the outside of the door and you close it, can you see the weatherstripping compressing against the door when it closes?
Toolmaker68 is offline   Reply With Quote
Old 01-27-2019, 02:35 PM   #4
JUSTA MEMBER
Rewards Points: 98
Check your door for a perfect flat surface.
Sometimes with age, abuse, or poor materials, they warp.
Get a 6 ' level, place it against the door, inside and outside, near the edge, and see if there is any gaps in the space where the level should be against the door, if any light then you can try to seal it, but it's better to get new doors, frame and all.
Sometimes there is a way to move the weather stripping closer to the door, is there screws holding the strip frame?
ED
de-nagorg is online now   Reply With Quote
Old 06-03-2019, 11:34 PM   #5
Rewards Points: 2
Not sure if anything ever happened with this. I'm experiencing this now and instead of moving the insulation location itself I've moved the door closer to the insulation by moving the strike plate, deadbolt strike, and the hinges forward say 1/4" depending on your gap of course. Predrilled the holes and used longer screws to ensure that they didnt fall into the previous ones. This worked like a champ. I've got two other doors to do this with but it has created a nice seal.
de-nagorg likes this.
Dubau2 is offline   Reply With Quote
Just replaced light fixture, now switch won't turn it off. 3 wires each side gregp1962 Electrical 12 04-16-2013 05:20 PM
Light Wiring Question mataguri Electrical 4 11-09-2011 02:15 AM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
bathroom light switch/outlet replaced and now triggering breaker first time diy Electrical 9 11-28-2009 11:38 AM
Replaced Light Fixture, additional wire? froddan Electrical 11 11-17-2009 10:55 AM
