Reducing Overhead Footstep Noise - Insulation - DIY Chatroom Home Improvement Forum
Old 02-03-2015, 11:57 AM   #1
Rewards Points: 12
Reducing overhead footstep noise
We're in the process of building out a home theater in our basement. It's a pretty old house, and creaking and stomping can be heard pretty loudly. From what I've read, there's not too much that can be done without dealing directly with the floorboards in the room overhead.
Since this is not an option at the present time, does anyone have any other creative solutions?
francote is offline   Reply With Quote
Old 02-03-2015, 12:02 PM   #2
Rewards Points: 129
I usually have volume turned up in my tv room loud enough that anything from above short of a basketball game probably wouldn't be heard. more likely lord of the rings would be interfering with what ever was going on the floor above.
That being said there are acoustic treatments to reduce noise although I wouldn't expect it to eliminate it.
jimn01 is offline   Reply With Quote
Old 02-03-2015, 12:27 PM   #3
Rewards Points: 12
Ha! "More volume" is the solution to many of life's problems.
Old 02-03-2015, 03:52 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 926
There are more than a few threads on here about soundproofing ceiling assemblies. If you Google sound isolation clips and resilient channel you should find several items that will help uncouple the framing from the downstairs.
Between the sound proofing of the framing and insulating the joist cavities, you can create a pretty good and near soundproof assembly.
Old 02-04-2015, 08:03 AM   #5
Rewards Points: 926
Something like this.
Old 02-04-2015, 08:05 AM   #6
Rewards Points: 12
Thanks windows. I was just researching resilient channels when your post came through!
Rattling Noise from Roof when windy drgillian Roofing/Siding 6 10-17-2018 07:35 AM
Upgrade Svc., Overhead; Bill vs. Estimate Question Rpsjr Electrical 6 04-22-2012 03:15 AM
reducing noise with goodman furnace cliftonian HVAC 23 03-06-2012 07:15 AM
Reducing A/c Pipe noise klingenfelter HVAC 6 07-31-2011 02:38 PM
Noisy furnace (with recording of noise) Jeffrey HVAC 3 01-23-2010 01:17 PM
