Redoing Old Basement With Strange Framing - Insulation - DIY Chatroom Home Improvement Forum
Old 03-21-2015, 03:14 AM   #1
Redoing old basement with strange framing
Hi I recently bought an older house approx 40 yrs. The basement is cold and the bedrooms covered in ugly panel board. My plan was to rip out the panelling re-insulate using roxoul and new poly then cover with gyproc. When I pulled of the panel board I found that the walls are framed with the 2x4's laid flat against the cement ie 4inch side to cement. The insulation is paper backed nailed on r7 fiber glass. I really don't want to reframe all the walls but don't know what other insulation option I have with such a narrow space to fill. Any suggestions? Thanks
21deebee is offline   Reply With Quote
Old 03-21-2015, 07:16 AM   #2
You can rip up some 7/16" OSB and fir that mess out then custom cut and fit some 2" closed cell foam board. If you like you can then cover the studs with 3/4" closed cell and get your total R factor close to 13. That is an expensive insulation job.
You could also fir out the walls by 2" and use regular R-13.
How you proceed depends in part on how well secured those studs are and how dry the basement really is.
In a home I planned to stay in and with a roomy basement, I might just build a new wall in front of what is there and use 6" fiberglass.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is offline   Reply With Quote
The Following User Says Thank You to Colbyt For This Useful Post:
Windows on Wash (03-21-2015)
Old 03-21-2015, 09:18 AM   #3
Rewards Points: 1,858
I'd agree on ripping out what there now and reframing.
May be able to reuse some of the old 2 X 4's.
To meet code in an occupied room there should have been outlets every 6', in a basement around here it must be a 20 amp. GFI protected.
Put 2" foam right against the concrete.
Old 03-21-2015, 11:47 AM   #4
Thanks for the ideas. I am going to price out both options . Would not thought of the firing out. I have already changed my plugs to tamper proof which is the code where I live. Thanks again
Old 03-21-2015, 04:20 PM   #5
Furring will do nothing to address the real issues.
Untreated wood can not be in direct contact with concrete.
Batts can not be in contact with the foundation.
Basement Framing Help Captivating Remodeling 4 07-16-2012 07:19 PM
basement framing / insulation question in storage portion of finished basement. cobra5laddict Insulation 5 03-22-2012 09:59 PM
Basement framing: PT wood? ChrisWz Remodeling 9 02-23-2012 11:09 PM
basement framing and insulating questions around ledge khatz Building & Construction 8 01-02-2012 12:50 PM
framing basement walls nickm1024cobra Remodeling 1 11-08-2010 12:06 AM
