Recessed Light Attic Covers - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-28-2014, 09:22 AM   #16
Residential Designer
AndyGump's Avatar
Rewards Points: 882
Send a message via Skype™ to AndyGump
Or just get rid of the leaky recessed cans all together and so you don't have that to deal with and put in some nice surface mount fixtures.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 06-29-2014, 04:27 PM   #17
Rewards Points: 81
I have always used foil tape and spend about 6 or 7 minutes on each one covering all "airtight" seams, rivets and anything else that could leak.
one cut is offline   Reply With Quote
The Following User Says Thank You to one cut For This Useful Post:
digitalplumber (06-29-2014)
Old 07-02-2014, 12:50 PM   #18
Home Performance
HomeSealed's Avatar
Rewards Points: 718
Use ICAT (insulation contact air tight) fixtures or build boxes. As WOW suggested, building boxes isnt a terrible idea even on those. Are you looking for any rebates from local energy-efficiency programs on this work? If so, check with them on the specs that they require. For instance, here in my area the boxes must be constructed of cement board, drywall will not fly.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
digitalplumber (07-02-2014)
Old 07-02-2014, 02:03 PM   #19
Rewards Points: 106
So are you using rafters for 2 sides then Sheetrock for top and other 2 sides? Or making complete Box?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 07-02-2014, 03:51 PM   #20
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 928
Depends on the layout of the home and if they are using trusses.
We usually build the whole box.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Old 07-03-2014, 10:30 AM   #21
Home Performance
HomeSealed's Avatar
Rewards Points: 718
+1. Generally building a whole box.
www.HomeSealed.com
Old 07-03-2014, 03:51 PM   #22
Rewards Points: 106
Tape and float pieces together?
Old 07-07-2014, 11:43 AM   #23
Rewards Points: 928
We pin and glue them together and then cover the seams with foam from the exterior.
digitalplumber (07-07-2014)
Replacing a chandelier with a recessed light. RyanD General DIY Discussions 5 01-19-2016 10:27 PM
Kitchen recessed lighting with no attic access? SimpleJack Electrical 10 11-13-2012 03:26 PM
Help; Suggestions for recessed shower light pdexter46 Electrical 1 03-31-2011 11:11 AM
Recessed light suggestions? vyjeff Electrical 1 04-27-2010 01:26 AM
Recessed light plan foiled? kcrossley2 Electrical 8 03-14-2007 11:08 PM
