Re-insulating Attic - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-07-2015, 12:11 PM   #16
Rewards Points: 92
Yes, triple 4's, 12 inch wide. They come in 12ft lengths, 12in wide.
MGK01 is offline   Reply With Quote
The Following User Says Thank You to MGK01 For This Useful Post:
craig11152 (07-07-2015)
Old 07-07-2015, 12:30 PM   #17
craig11152's Avatar
Rewards Points: 1,220
looks like your on the right track. A general rule of thumb you can't have too much venting.....as long as soffits (intakes) equal or exceed roof (exhaust) vents.
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
Old 07-07-2015, 07:00 PM   #18
Registered User
Rewards Points: 526
You are under IBC; http://www.cmdgroup.com/building-codes/michigan/
3' vertical distance between vents- no vapor retarder; http://publicecodes.cyberregs.com/ic..._12_par004.htm
Problem with those small holes/punches is they tend to clog with dirt from moisture going through the itsy hole, be sure to clean them regularly- with a brush- not the water hose. http://cthandiman.com/services/vinyl...ts-and-fascia/
Gary
Old 07-07-2015, 07:38 PM   #19
craig11152's Avatar
coincidentally a similar issue turned me off to ridge vents. Eventually the fiberglass or foam filters get as dirty as your furnace filter yet there is no way to ever change them.
The Following User Says Thank You to craig11152 For This Useful Post:
Gary in WA (07-09-2015)
Insulating converted stand-up attic to living space mudpaws Insulation 3 09-19-2013 04:28 PM
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Insulating knee wall and attic kujo Building & Construction 0 05-06-2013 08:10 PM
Attic Ventillation Problem. Why Now? Hubs Roofing/Siding 2 03-19-2013 10:23 AM
finishing insulating attic Roundeye Insulation 12 01-12-2012 09:10 PM
