R38 Insulation In 2X6 Joist. - Insulation - DIY Chatroom Home Improvement Forum
Old 04-05-2019, 07:10 PM   #1
Rewards Points: 18
R38 insulation in 2X6 joist.
Hi, i have 2X6 ceiling joist with 16" at center. Can i install R38 faced insulation which is around 10" tall?
Please advice on what options do i have with 2X6 joist to get R38 value.
simonmax is offline   Reply With Quote
Old 04-05-2019, 07:14 PM   #2
user_12345a's Avatar
Rewards Points: 88
Re: R38 insulation in 2X6 joist.
You can if there's enough space above the joist. The batt can't get compressed.
You won't be able to find more than R-24 if you need 6" max thick.
You need foam, likely sprayed in layers to get even R30 with 6".
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Old 04-05-2019, 08:52 PM   #3
Rewards Points: 222
Is this a ceiling with an open attic space above?
If so then r-19 would fill the cavity (R-23 if Roxul) and then another layer of r-19 perpendicular across the top of it.
What is the code requirement where you live?
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Rim Joist insulation options? learmoia Insulation 4 10-11-2012 12:02 AM
Floor joist insulation help Drewkernovich Insulation 3 01-05-2012 09:50 AM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
Rim Joist Insulation ja191992stg Building & Construction 53 03-22-2010 08:41 PM
