R-13 Into Interior Wall (new Wall At Bottom Of Basement Stairs) Paper Direction? - Insulation - DIY Chatroom Home Improvement Forum
Old 10-15-2015, 11:58 AM   #1
Rewards Points: 510
R-13 Into Interior Wall (new wall at bottom of basement stairs) Paper Direction?
I built a wall at the bottom of my stairs to the basement (and a door of course that is surrounded by the wall).
Does it matter which direction the paper faces regarding the R-13 Pink Insulation I am installing?
They say that the "paper side" should be on the "inside of the home" side so that the pink insulation/unfaced side is facing the cold and the "paper" side is facing the inside of the home. The basement in my case is cold so I assume
the pink side should face the basement and the paper side should face the stairs?
Also, for sound proofing, can I fit two layers of 3.5 inch insulation in between the 3.5" (2 x 4) studs instead of one 3.5" R-13 layer for the walls?
HTFreak is offline   Reply With Quote
Old 10-15-2015, 12:56 PM   #2
griz's Avatar
Rewards Points: 572
Barrier faces the warm side.
Two layers of insulation will do nothing for sound proofing.
griz is offline   Reply With Quote
The Following 2 Users Say Thank You to griz For This Useful Post:
Wild Willard (10-15-2015), Windows on Wash (10-15-2015)
Old 10-16-2015, 09:44 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 766
Sound proofing is more about addressing the vibrations via framing members.
More insulation, unless it goes over the framing, won't do anything.
Old 10-16-2015, 04:48 PM   #4
Registered User
Rewards Points: 526
I agree, thickness of the wall vs. density, pp.3:http://www.certainteed.com/resources...%20Control.pdf
"Warm in winter side", works for all climate zones.
Gary
Vapor barrier on basement wall gregsenne Insulation 4 10-12-2012 11:27 PM
condensation behind vapor barrier of walkout basement wall fusion_ta66 Remodeling 10 08-01-2012 10:14 PM
Water seeping though bottom of basement stairs Sforza General DIY Discussions 18 03-11-2011 01:42 PM
Leaking Basement Wall MStocks Building & Construction 3 10-29-2009 09:57 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
