Is R-13 Decent Insulation? - Insulation - DIY Chatroom Home Improvement Forum
Old 08-31-2013, 11:36 PM   #1
Rewards Points: 87
Is R-13 decent insulation?
I had to do some sheetrock repair in my house, and it gave me a chance to find out what kind of insulation it had. It said R13. Is that good insulation? What is it that they're using these days on an typical house? I've heard that R-30 exists, but I don't know if its true. I know very little about insulation.
Bennylava is offline   Reply With Quote
Old 09-01-2013, 05:51 AM   #2
Rewards Points: 1,916
http://www.energystar.gov/index.cfm?...sulation_table
All depends on where the insulation was and what it was insulating and where you live?
It's best with questions like this to include your location in your profile. (not just mention it in your post.)
Just go to quick links to edit.
If this was inside a wall and the walls only 2 X 4 you can not simply remove the R-13 and expect to fit a piece of R-19 if both are fiberglass. R-19 is thicker. Compressed insulation does not work.
Want to add R value you would have to build out the walls or have the walls spray foamed.
Old 09-01-2013, 08:22 PM   #3
Rewards Points: 87
Sorry bout that I should have put more info. I'm in TX, so its regarding the heat. The R13 was in an inside wall, not facing outside towards the outdoors. So I see your point. You are saying that the insulation may be different on the outside walls, correct?
Old 09-01-2013, 10:31 PM   #4
Rewards Points: 1,602
Most houses don't even have insulation in interior walls. What rooms is this wall between?
R-30 Would be found in an attic or a basement ceiling.
mikegp is offline   Reply With Quote
Old 09-01-2013, 10:54 PM   #5
Rewards Points: 87
This is in a wall that runs between the living room, and the master bedroom.
I am curious though. What exactly, is the best insulation that you can put in your exterior walls, and attic? What's the best technology out there?
Old 09-02-2013, 05:00 AM   #6
I'd bet someone put that there to try and deaden the sound, so someone could sleep while people were in the living room. Only other reason would be if at some time this was an outside wall and an addition was added.
Here's some general info.
What insulation is used is decided by location in the home and your budget.
http://web.ornl.gov/sci/roofs+walls/...on/ins_02.html
Other things that have an effect.
Air sealing (sealing up any holes in the attic, walls, and crawl spaces where plumbing or wiring was run)
Proper roof venting. Must have soffits and some form or roof venting. I prefer a ridge vent so the whole roof gets vented.
Old 09-02-2013, 09:33 PM   #7
Rewards Points: 87
No budget really. I'm willing to spend a lot of money to get my electric bill low.
Old 09-03-2013, 06:52 AM   #8
I think closed cell spray foam will be your best bet if you really don't care about price. It air seals, insulates, and is a vapor barrier all at the same time.
Old 09-03-2013, 08:50 AM   #9
Rewards Points: 87
Its better than any roll-out insulation? Like the pink stuff.
Old 09-03-2013, 11:09 AM   #10
Much.
Old 09-04-2013, 07:19 AM   #11
ccarlisle's Avatar
Yes, technically, spray foam insulation is the best combined air and moisture-sealing method there is, but whether or not it is called for - or applies to your house - is another matter altogether. Have you had an energy audit performed recently?
An energy audit will tell you a lot about the application of several different forms of insulation in your particular circumstances, and explain to you the payback of doing a number of things to lower your energy bill. I mean saying spray foam is best is fine - but does it even apply to your circumstances is a question we cannot know; for example, would it go on the outside - or the inside - and then is it worth taking down all your walls, apply the foam then put everything back together. And have you air-sealed the best you can? An energy audit will tell you all this - and these guys are independent contractors so they have no dog in that fight...
Let us know.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 09-04-2013, 08:43 AM   #12
Rewards Points: 46
One trick I like to do on exterior wall remodels is to add a 1/2" layer of foam board behind the sheetrock. It's pretty cheap and goes up easy and works well with the existing insulation. It does two things: First it will add r-value to the wall, secondly it will greatly reduce what is called "Thermal Bypass". This is the heat flow through the wall studs that essentially "bypasses" the insulation. There can be be some challenges if you have doors/windows but outlets and lights are pretty easy to move out. Just use longer drywall screws and you are done.
AtticFoil.com is offline   Reply With Quote
Old 09-04-2013, 03:41 PM   #13
Rewards Points: 150
The foam board is a really good idea. Usually walls are done with r-19 and attics r-30 with vapor barrier being on living or warm side. Depends on location. I use the closed cell spray foam with some fiberglass on top. Stops all drafts and is your vapor barrier
romex1220 is offline   Reply With Quote
Old 09-04-2013, 10:29 PM   #14
Rewards Points: 87
Much.
Ok well I wasn't really going to change my insulation right now, more just trying to learn something about insulation. So is R-30 about as high as the roll out stuff can go? Also, what would be the R-rating of the spray on insulation?
Old 09-10-2013, 09:39 AM   #15
Are you sure it's legal to have foam at the edge of electrical boxes? I think you'll need a box extender in that situation. Rigid foam is pretty flammable and creates very dangerous gases. I don't think many areas would let that fly.
Insulation question for vaulted home Talgonadia Insulation 3 08-22-2012 06:06 AM
?'s about foil-faced "bubble wrap" insulation badger73 Insulation 5 06-25-2012 05:09 AM
Several Insulation Quotes, Big Decisions to make knotquiteawake Insulation 2 05-04-2012 11:16 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
