Quick Question - Sealing Rim Joist And Sill Stack - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By schreibdave
Old 05-03-2019, 10:54 PM   #1
Rewards Points: 116
quick question - sealing rim joist and sill stack
i was in the process of sealing the rim joist with 3" and foam but then noticed three stack sill.
in second pic you can see the pressure treated sill sitting on top of gasket/foam and then three stack wood. how do i insulate this area?
do i grout the seak and in between the stack?
<blockquote class="imgur-embed-pub" lang="en" data-id="a/q0UmaQ9"><a href="//imgur.com/q0UmaQ9">Sealing the rim joist and the 3 stack sill</a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
jackallis is offline   Reply With Quote
Old 05-03-2019, 11:14 PM   #2
Rewards Points: 116
Re: quick question - sealing rim joist and sill stack
pics
https://imgur.com/a/q0UmaQ9
Old 05-03-2019, 11:21 PM   #3
retired framer
Rewards Points: 4,810
Just like the rest, when or if you build a wall in front of this the top plate of the wall is extra wide so it reaches all the way in and touched the top one and when you insulate the wall, all is covered.
Do not use flat bottom gables with scissor trusses.
The Following User Says Thank You to Nealtw For This Useful Post:
jackallis (05-03-2019)
Old 05-03-2019, 11:27 PM   #4
Rewards Points: 116
i did not understand word you said, i am sorry.
so when i insulate the joist area do i leave the sill alone? people keep saying
seal around the foam gasket where the sill sits on but i got 4 of them. how do i insulate that area?
i do have dry wall and it stops 90 degrees to the first wood.
Old 05-03-2019, 11:53 PM   #5
retired framer
This is what it would look like in a finished basement from the sides with a wall built in front of the concrete wall, If you want to bring foam all the way down to cover those plates and cover that with drywall, like the first picture, it won't hurt anything.
Old 05-10-2019, 08:55 AM   #6
Collector of tools
Rewards Points: 142
I would caulk the seams between the sill plates and cut and glue rigid foam over them. Then spray foam any gaps.
Dave Sal likes this.
schreibdave is offline   Reply With Quote
Old 05-10-2019, 12:23 PM   #7
Rewards Points: 7,804
No fiberglass against any cold surface as air will get through and form condensation.
Emphasis on sealing any air leaks, I like the caulk suggestion, as a small leak will defeat a lot of rigid insulation and effort.
Keep in mind that insects and critters will use any cavities or paths you create.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
Old 06-10-2019, 11:13 AM   #8
Rewards Points: 116
what kind of rigid foam should I use? pink/blue/faced/unfaced?
Sill plate washers and rim joist question PandJ Building & Construction 13 04-01-2016 05:35 AM
Repair/replace sill plate and joist ends heybales Building & Construction 5 02-16-2013 11:33 PM
Sill plate and rim joist question bhasty Building & Construction 3 10-15-2009 03:07 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
Sill and Joist Question jkspup22 Building & Construction 5 03-26-2008 08:18 PM
