Questions About Incapusluating Basement - Insulation - DIY Chatroom Home Improvement Forum
Old 10-25-2014, 12:55 PM   #1
Rewards Points: 64
questions about incapusluating basement
Looking to encapsulate a crawl space unde addition. Crawl space is only accessible from the outside.
1. It has a poured concrete floor should I still cover it with vapor barior?
2. It has about 1 ft high concrete walls what should I insulate them with.
3. It has another 3 ft of standard 2x6 ext walls. Will standard fiberglass insulation work for those.
4. Heat runs are another matter. I can install a heat vent but bot a return. Even if I skip this step will it still be better then nothing.
mattlreese is offline   Reply With Quote
Old 10-25-2014, 02:10 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
1. Not needed if there are no water issues inside the crawl and moisture management is proper.
2. Rigid foam or Spray foam work best.
3. Yes, but I would consider rigid here as well to help with the air tightness and thermal break.
4. You can install a heat vent and most times a return is not needed if the amount of supply air is small.
Old 10-26-2014, 03:21 PM   #3
Rewards Points: 64
New plan. I want to spray foam the entire crawl space. Walls and the ceiling which is the floor of my living room.
Are there any downsides to this approach?
Old 10-27-2014, 06:22 AM   #4
Rewards Points: 906
Other than not being correct...?
You don't need to spray foam the ceiling if you insulate the walls properly.
http://www.buildingscience.com/docum...n-crawlspaces/
Old 10-27-2014, 07:06 AM   #5
Rewards Points: 64
After looking into it more insulating the walls is what I decided to do. I was originally worried about the plywood door to the outside but I figured out how to beef that up too.
Eventualy i will run a heat run in there, but for now I am going to use the leakage form the HVAC in there already to heat the space.
Old 10-27-2014, 09:27 AM   #6
Rewards Points: 906
You won't need much heat to keep it warm if it is airtight.
Pop a couple of drill holes in a supply side and you will be fine.
Replacing basement floor questions strategery Concrete, Stone & Masonry 3 07-12-2014 07:05 PM
Yet More Basement Questions DocWard General DIY Discussions 8 06-29-2011 10:24 PM
Basement Trap and confused questions Ryan7 Plumbing 15 02-26-2011 10:42 AM
Adding heat to a basement, newbie questions frizbplaya HVAC 3 01-28-2011 02:57 PM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 08:49 AM
