Proper Sky Light Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 02-16-2014, 01:19 PM   #1
Rewards Points: 150
proper sky light insulation
does any one know if velux has any type of a guide in print regarding the proper way to insulate around sky lights and sky light shafts in cold climates?
hpyjack2013 is offline   Reply With Quote
Old 02-16-2014, 01:39 PM   #2
I found this in my VSE installation guide.
Vapor escape and vapor barrier:
Insure tight joints where the finish material connects to the finish groove and to the ceil- ing - detail 1.
Install vapor barrier to the finish groove - details 2.
Underlayment:
Install underlayment up against the frame on all four sides and establish over-flashing drainage at the top - details 2.
Consider use of VELUX underlayment (type ZOZ 121 in US and ZOZ 211 in Canada) in areas with severe weather conditions and on roofs with low roof pitch.
Insulation:
Insulate carefully around skylight always maintaining min 1/2" (15 mm) distance to flashing - detail 3.
In cold areas a combination of flared and 4" (100 mm) perpendicular lining at top and bottom allows for better insulation - detail 4.
Dan
djlandkpl is offline   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
hpyjack2013 (02-16-2014)
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Proper way to switch a ceiling light. CoconutPete Electrical 6 06-11-2010 07:19 AM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
