Partially Vented Cathedral (No Roof Vent) - Insulation - DIY Chatroom Home Improvement Forum
Old 06-24-2020, 10:00 AM   #1
Rewards Points: 35
Partially vented cathedral (No roof vent)
I had a plan to deal with this room, but now I am not sure
The whole bathroom is being redone. It has had a serious ventilation and mold problem in the past
The whole room sticks out of the side of the house about 8 feet. I had thought that the roof was a vented cathedral with a soffit and ridge vent. The outside of the roof sure looks like it has a roof vent
The old insulation came down today and lo and behold there is no ridge gap for the vent to work properly. The plywood is right up against the header. There are two measly Insulation dams near the soffit vent which seem quite useless
My original plan was to pack the whole 12 Inch cavity with rockwool, then use a polyethylene vapor barrier and acoustic sealant to keep the bathroom moisture in the bathroom and have everything dry to the outside. Does this still make sense if there is no ridge vent?
Some pictures below. First is overall view. Second shows soffit vent. Third is up near the header showing no vent gap
Sent from my SM-G950U using Tapatalk
kaalapurushha is offline   Reply With Quote
