Paper Or Plastic? - Insulation - DIY Chatroom Home Improvement Forum
Old 02-18-2020, 05:31 PM   #1
Rewards Points: 38
Paper or plastic?
This may be an odd question - I am planning to insulate my shed/workshop and add air conditioning. It will be used off and on and will at times be unoccupied. I am planning on using fiberglass batts (R-13) for the wall and cover with plywood. Are there any pluses to used unfaced batts and add plastic sheeting or can I just use paper faced batts?
Easypick is offline   Reply With Quote
Old 02-18-2020, 05:57 PM   #2
retired framer
Rewards Points: 278
Re: Paper or plastic?
If you are just using AC you are more worried about air from the outside . your biggest problem will be holes in the wall, use exterior wall boxes that have a gasket behind your drywall or plywood. .
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 02-18-2020, 08:58 PM   #3
APA
Rewards Points: 382
I would get kraft faced and staple them in. It's just a shed. I assume you will be using a window unit? There is no reason to go overboard for a workshop.
APA is offline   Reply With Quote
Old 02-18-2020, 10:48 PM   #4
user_12345a's Avatar
Rewards Points: 36
Batts with paper are garbage, we don't have them in canada.
In a hot climate, humid climate with no real winters you want the barrier on the exterior side.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Old 02-18-2020, 11:33 PM   #5
APA
Rewards Points: 382
The poster is in Texas and its a shed. He could shred newspaper and put in there.
Old 02-18-2020, 11:36 PM   #6
APA
Rewards Points: 382
This board will run you crazy with people vying to be right. I guess you could have it spray foamed and have a heat pump installed. Maybe just tear it down and rebuild it once or twice. Kraft faced bats are not garbage. They are used successfully all over the place.
