Open Web Floor Truss Insulation Options - Insulation - DIY Chatroom Home Improvement Forum
Old 11-28-2016, 07:57 PM   #1
Rewards Points: 4
Open Web Floor Truss insulation options
Howdy gang
We are currently building our first (and last) house in Western NC. ~725sqf main floor with a daylight unfinished basement. The floor uses open web trusses (2x4 19.2" OC).
My question is how the heck are we supposed to insulate those things? We've started with faced batts and it's not going well. Supporting them is a pain.
What options are there for DIY types?
Any advice would be appreciated.
Thanks!
--Chris
Bodo is offline   Reply With Quote
Old 11-28-2016, 08:26 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 942
Re: Open Web Floor Truss insulation options
Insul-web helps support them.
Most insulation depots should have them.
Old 11-28-2016, 08:36 PM   #3
Rewards Points: 4
That might be an option, but will need to get with the inspector to see if he'll allow it.
These trusses are 20" deep and we're putting R30 insulation in and that only fills about half the depth. I was instructed that the paper has to be in contact with the subfloor...
Old 11-29-2016, 07:56 AM   #4
Rewards Points: 222
Hi Bodo and welcome to the forum. I'll have to do some searching on the paper against the bottom of the floor (if you go this direction) but one of the experts in the field stated that paper to the warm side of a home was not intended for basements. It will be tough to find but his logic was good. Having said that, in either case I don't like exposed fiberglass insulation. The mice do and heat, air, and moisture pass right through it.
Now, as for going that direction, there might be a better option, insulate the foundation walls and condition that space. Much easier to insulate the walls than those geometric trusses and you solve the dilemma of what to do with the basement, vent or no vent.
Any flexibility as to where that insulation goes?
Bud
Bud9051 is offline   Reply With Quote
crawlspace insulation kenaran Insulation 9 08-08-2015 07:39 PM
Open studs and insulation in duct behind honeywell humidfier filter Ronz40 HVAC 0 10-15-2012 05:49 PM
Exterior Insulation Options AlphaPilot Insulation 2 10-13-2012 09:39 AM
Rim Joist insulation options? learmoia Insulation 4 10-11-2012 12:02 AM
open cell sprayed insulation and PEX danster44 Insulation 17 10-18-2011 08:40 AM
