Ontario Building Code Min R-value For Vented Cathedral Ceiling - Insulation - DIY Chatroom Home Improvement Forum
Old 10-11-2017, 04:04 PM   #1
Rewards Points: 172
Ontario Building Code min R-value for Vented Cathedral Ceiling
I want to condition my attic and knee wall in my 1-1/2 story home, to create more space for storage and new HVAC.
I'm having a hard time figuring out the requisite minimum r-value for the rafter cavities.
It looks like the Ontario code was updated post-Dec 31/16.
http://insulation.owenscorning.ca/pr..._Jan_01_17.pdf
It requires an r-value of 31 for "Ceiling Without Attic Space," and an r-value of 60 for "Ceiling with Attic Space."
My plan for 8" rafters is to do:
  • 2" site-built baffles from vented soffits to ridge vent.
  • 5 1/2" of mineral wool insulation (r-value of 22)
  • 2" of rigid polyiso foam (r-value 10), which will also act as vapour barrier.
Will then add strapping and sheetrock on top of the rigid foam. This should give me a nominal r-value of 32.
But - because this will be vented - does it count as "ceiling with attic space" (with the attic space being the 2" baffle), or can I get away with the r-31 minimum?
Before you ask, I know that closed-cell foam will give me more options, but I'm trying to be cost-conscious.
Thanks all!
jmetrail is offline   Reply With Quote
Old 10-11-2017, 04:15 PM   #2
retired framer
Rewards Points: 610
Re: Ontario Building Code min R-value for Vented Cathedral Ceiling
It sure sounds like ceiling with out attic space.
The venting alone would not be called an attic.
Drainage Slope - Ontario Building Code pete0403 Plumbing 3 12-30-2012 01:31 PM
Building Code Requirements: Basement Stairs (Quantity) dutchswan0311 Building & Construction 27 09-19-2011 06:13 PM
Replacing ceiling fan on cathedral ceiling? wizzy Remodeling 1 03-22-2009 03:04 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 06:35 PM
Rafter Thrust / Cathedral Ceiling sseeley Carpentry 8 10-06-2005 11:19 AM
