Old Sheathing, Is It Safe? - Insulation - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Windows on Wash
  • 1 Post By joecaption
Old 03-25-2020, 10:27 AM   #1
Rewards Points: 4
Old sheathing, is it safe?
Ive got two 4x8 sheets of celotex sheathing, made out of some kind of brown material On back of sheets it says insulating sheathing, IBrated R2.06. Is this full of asbestos? Can I use it? Is it safe? If not safe how do I dispose of it?
Frogspan2017 is offline   Reply With Quote
Old 03-25-2020, 10:47 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,046
Re: Old sheathing, is it safe?
Break it up and trash it. Don't breath the dust. Its unlikely to have any asbestos in it, but its still not good for you.
Dave Sal likes this.
Old 03-25-2020, 10:55 AM   #3
Rewards Points: 1,916
Notice also where it also says something about being flammable?
Really want that in your walls?
Old 03-25-2020, 11:00 AM   #4
retired framer
Rewards Points: 924
Is there a date on it?
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Nealtw is offline   Reply With Quote
Old 03-25-2020, 11:24 AM   #5
Hammered Thumb
Rewards Points: 168
If it is the brown "fiberboard" sheathing from the 70s/early 80s, then it is made from cellulose fibers. Just dispose of as any construction waste.
Older 1920-60s types of products Celotex made for other uses may have asbestos though. Some reading here: Celotex
3onthetree is offline   Reply With Quote
Old 03-25-2020, 11:39 AM   #6
retired framer
Rewards Points: 924
They still use it here behind drywall for sound proofing, well help with the sound anyway.
figure 7-14
Old 03-25-2020, 02:17 PM   #7
Rewards Points: 5,282
It is ok to use within its limitations. It is not structural so it cannot be used in braced panel situations without other bracing. It does not hold nails. Siding or subsequent applications have to be installed with longer nails into studs. Used as intended, it is ok to use.
Houses in western NY used to be sheathed with it. The framer would either put diagonal bracing at the corners or substitute one sheet of plywood both ways at each corner.
Old Thomas is offline   Reply With Quote
