Non Toxic Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 02-09-2015, 07:22 PM   #1
Lord of Slums
Rewards Points: 1,974
Non toxic insulation
I have been researching ways to insulate the home that I live in. I definitely want something that my bloodhound of a wife will not smell or react to. She claims that spray foam smells terrible and their is no way it is getting sprayed in the house.
The standard pink is out. The formaldehyde free pink maybe possible. She claims the denim smells lie fabric softner. The blown in has all that fire retardant so that is out.
Has to be a natural material that is safe. The county will not let me raise sheep here, but I have a tenant in Detroit that can raise a dozen or so and bring me the wool to stuff in the walls.
In can not live in the house if the wife is unhappy. I want to finish out my basement so I need to find an insulation that she likes. What about hemp or flax? Do they use sheep's wool? I can get a boat load of sheep pretty cheap from a guy I know, he owes me a big favor.
This is sort of a problem for me now, I will be selling the house soon but wife does not want something off gassing or smelling bad while we still live here.
mj12 is offline   Reply With Quote
Old 02-09-2015, 09:06 PM   #2
Rob
Robpo's Avatar
Rewards Points: 826
My house is strawbale but not in the attic. I think loose straw would be too much of a fire hazard but if you could enclose it in something like sheetrock or something. Just a thought.
Robpo is offline   Reply With Quote
Old 02-09-2015, 09:30 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 830
Anything you get will require some sort of fire retardant. We use borate only cellulose and have never had a complaint. Boric acid is very innocuous as stabilizers go.
Old 02-09-2015, 09:31 PM   #4
Rewards Points: 830
Get a sample of aircrete too.
Is this strictly for a basement?
Old 02-10-2015, 02:48 PM   #5
Lord of Slums
For now, mostly likely only for the basement
Old 02-10-2015, 04:26 PM   #6
Rewards Points: 830
If these are poured or block basement walls, rigid foam works great. It is manufactured under very controlled conditions and, depending on the board, has very little VOC off gassing. You could probably put a section in front of your wife and she couldn't smell a thing if it has been out of the package for a while.
You still need to seal up the bands and you can do that with a non-VOC caulking/sealant.
Aircrete is nice but it isn't cheap. I have a customer getting ready to use it and a modest sized basement was over 5K for the exterior walls.
Old 02-10-2015, 06:33 PM   #7
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
here is all the insulation you will need to purchase. Nothing else appears like it would be acceptable to your wife:
The Following 2 Users Say Thank You to nap For This Useful Post:
mj12 (02-10-2015), Windows on Wash (02-11-2015)
Old 02-11-2015, 08:57 PM   #8
Lord of Slums
Well, apparently the wife has decided. She found some glass bottle recycled woven insulation batts. She was trying to get some hemp stuff but it was going to take to long to get or something.
I can post back with specifics, sounds like it is fiberglass insulation someone fancied up. The shipping was somewhere around 600 dollars. The insulation will probably be about the same. I just paid for a whole pallet. What ever it takes to keep the Mrs happy!
Old 02-11-2015, 09:14 PM   #9
Rewards Points: 830
Hope it works for you. Batts usually do horrible on basement walls.
Happy wife...happy life.
Old 02-11-2015, 10:11 PM   #10
Registered User
Rewards Points: 526
Compare Case #3 to Case #4, starting page 47+: http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja
Gary
Old 02-12-2015, 12:07 AM   #11
Rewards Points: 139
Roxul. http://www.roxul.com/
b4bhomeowner is offline   Reply With Quote
Existing blow in insulation vs new insulation - Keep or redo? Jaxx Insulation 9 01-17-2014 08:26 AM
Is my Roxul sound insulation toxic? Brit Insulation 20 08-12-2012 09:13 PM
Several Insulation Quotes, Big Decisions to make knotquiteawake Insulation 2 05-04-2012 11:16 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
