No Insulation - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Bud9051
Old 11-23-2019, 04:28 PM   #1
Rewards Points: 296
No insulation
Hello...
I have an older lake house with no insulation inside the walls. I have had several spots open doing electrical. All I have seen is a very thin black paper on the outside behind the wood exterior.
The inside is finished with three quarter inch solid wood paneling. Picture.
The outside is cedar boards laid on top of studs with an additional cedar board in the middle to hide the gap.
I could remove every outer cedar board put in fiberglass then put every board back in place, but that would be a lot of work. They are nailed, and I have had a few boards off, but most I removed did crack or split when removing.
I did see something on tv where they drilled a hole outside and filled it with blown in insulation, but not sure about it so I ask.
slipparee is offline   Reply With Quote
Old 11-23-2019, 04:39 PM   #2
retired framer
Rewards Points: 4,496
Re: No insulation
I would look close at doing it from the out side.
If you can see the nails you could use a cats claw and then turn the board painted side in. That would be a lot of work but you would get a much better insulation job.
https://www.amazon.ca/STANLEY-55-115...44546774&psc=1
Do not use flat bottom gables with scissor trusses.
Old 11-23-2019, 04:42 PM   #3
Rewards Points: 7,696
Re: No insulation
If there is a deep enough cavity between inside and outside the blown-in insulation is a frequent solution. I would prefer cellulose as it can be installed to a denser level, more air tight.
Get some estimates from local insulation companies and take notes. in some cases they can install it clost to the same price you would buy just the insulation. Then they do the drilling and plugging.
Bud
SPS-1 likes this.
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
