New Construction Spray Foam Insulation - Insulation - DIY Chatroom Home Improvement Forum
Like Tree7Likes
Old 02-10-2019, 06:28 PM   #1
Rewards Points: 2
I am acting as GC for my new construction home build and I was wondering if anyone here has had experience with spray foam insulation for an entire house? I really think it will make a difference over time, but I am having trouble coping with the costs vs benefits.
Has anyone sprayed their own home, or had it done by a professional? In your opinion, was it worth it? Is it noticeable? Its sooooo expensive!!
Oh - and an important bit of info: I plan on spraying the insulation by myself. I can't justify hiring a contractor, so if it is to be, it is up to me.
Velosprints is offline   Reply With Quote
Old 02-10-2019, 06:36 PM   #2
Rewards Points: 17,890
Re: New Construction Spray Foam Insulation
Is it better, yes.
Is it a DIY job NO WAY!
Old 02-10-2019, 06:38 PM   #3
Rewards Points: 2
Why?
Old 02-10-2019, 06:46 PM   #4
Rewards Points: 5,770
We need to know your climate region, add a nearby big city to your profile.
I haven't done it because it cost too much, sound familiar.
I'm in the energy business and my take on spray foam insulation is the mfg's take so much profit it is barely cost effective use in a residential home. Plus, spray foam was more popular when homes were not well sealed. Today one can built a very tight home so the air sealing properties of foam add little to the benefit list.
Air quality inside a home requires a lot of fresh air. Once sealed super tight, which foam will do, you MUST add ventilation, search HRV (heat recovery ventilators).
IMO, DIY an entire house would be out of the question, bigger topic. Plus, using conventional well tested methods you can build a very efficient home all well within the DIY approach. Search "net zero" or "energy efficient" homes.
Bud
joecaption and Yodaman like this.
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
Old 02-10-2019, 06:49 PM   #5
Rewards Points: 2
I appreciate the response Bud. I live in northern VA in between Winchester and Leesburg. Does spray insulation help at all with sound dampening? The area Im moving to gets extremely windy, and Id love to dampen some of the noise.
Old 02-10-2019, 06:50 PM   #6
Property Mgt/Maint
Rewards Points: 6,368
I feel your pain brother. When I did the complete remodel of my existing home I went out for spray foam quotes. The quotes came back at 4 to 5 times the cost of what I could do in fiberglass. So you can guess which route I took.
But there are some advantages to the foam which fiberglass is lacking. Air sealing is huge in todays super tight homes. High density foam excels here. Areas like around the the rim joist are difficult to seal and foam is great here. Other areas where achieving the desired R value in fiberglass might be difficult, high density foam is about as good as gets. Cathedral ceilings come to mind.
You might ask you contractor to supply some ROI numbers to help wrap your head around the extra cost.
If you decide you need or want the foam, hire it out. Nearly everything I have read about DYI spray foam is negative. Cost savings is minimal as actual yields are lower than stated.
(this is bulk coverage spraying, not spot spray which I went through 2-3 cases? of great stuff)
[political signature removed]
Yodaman is online now   Reply With Quote
Old 02-10-2019, 06:56 PM   #7
Rewards Points: 2
This is all good info. Thank you! To be honest, its my wife who is pushing the DIY foam job. I feel like wed be in over our head QUICK
Old 02-10-2019, 07:06 PM   #8
Rewards Points: 7,188
Originally Posted by Velosprints View Post
Why?
Because if you screw up the mixing, it won't fully cure, and will off-gas toxic compounds for a very long time. (i.e bring out the bulldozer)
Also, the chemical reaction as it cures creates heat. Because it is such a good insulator, the heat has trouble getting out. If you spray it too thick, it can catch fire.
SPS-1 is online now   Reply With Quote
Old 02-10-2019, 07:07 PM   #9
Even doing your own work or being your own GC has a lot of kinks that need to be considered and there are several threads here along those lines. In some locations a home owner can do almost everything, but in other places licensed contractors are required.
Do you have a piece of land already?
Bud
Old 02-10-2019, 07:08 PM   #10
Rewards Points: 2
Sure do. Second floor walls going up tomorrow.
Old 02-10-2019, 07:18 PM   #11
Building it with 2 X 6 walls?
I live right on the bay in VA and wind noise has never been an issue.
Old 02-10-2019, 07:22 PM   #12
Rewards Points: 2
Unfortunately no. 2x4.
Old 02-10-2019, 08:56 PM   #13
Rewards Points: 618
With 2x4 you won’t be able to do more than r-13 I believe. Why not 2x6?
What about roof? You doing trusses? Rafters? 2x12 rafters? Vaulted ceiling?
I’m building a house now and also acting as a GC. I’ve been doing a lot of reading because I want my house to be perfect.
We did spray foam in a metal shop that we currently live in and it is very good but I get condensation where the chimney pipe exits the building. Other than that I like spray foam.
But I’m not doing it on my home. First because of cost and second because I believe you can do a good job if you do everything by the book with fiberglass.
Can you even do 2x4 in VA? New construction? R-13 is pretty weak.
Richard Pryor is offline   Reply With Quote
Old 02-10-2019, 09:00 PM   #14
Rewards Points: 618
Oh, and forget about spray foaming your own house. It’s definitely not a diy job. Fiberglass is and you can save a lot of money that way.
Old 02-11-2019, 07:46 AM   #15
Property Mgt/Maint
2 x 4 walls and R13 fiberglass is light for the climate zone 4 recommendations. Are you planning to use Foam sheathing on the outside?
http://insulationinstitute.org/wp-co...12/VA-2012.pdf
Should I install the spigot before or after the spray foam insulation? rocktop Painting 1 09-12-2017 10:08 AM
What type of spray foam and adhesive is best to use with XPS insulation? Studly Insulation 1 11-01-2014 01:56 PM
Home Energy Audit & Spray Foam Insulation sweets Insulation 7 09-08-2011 10:45 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
spray foam insulation jdgeorge Building & Construction 2 03-24-2009 05:15 PM
