Need Help Identifying Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 02-08-2015, 07:46 PM   #1
Rewards Points: 2
Need help identifying insulation
Greetings all. My current situation has me moving into a house that may not have seen an update since 1950 so I may be getting comfortable in this forum.
In an effort to patch together the plumbing enough to take a shower; I noticed puffs of dust emanating from a chunk of insulation under the tub with every bang, clunk, tap, or movement of the pipes. I aborted the project for now in light of the fact that it happened to be the area I was working in and I am hoping for some help determining the chances of whether it is likely to be a source of asbestos fibers or not.
I have attached a couple pictures taken from below, one of the exposed portion and one of the full section, but I fear any markings that may have been on the paper are obliterated. I have not found any pictures online of any asbestos insulation it resembles but I have found pictures of cellulose insulation that does look similar. I have no experience to draw from, though, so I hope others can give a more informed opinion to enable a more accurate assessment of the risk.
Need help identifying insulation-insulation-under-tub-exposed.jpg   Need help identifying insulation-insulation-under-tub-all.jpg
mralaska is offline   Reply With Quote
Old 02-08-2015, 10:10 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 944
Looks like asbestos to me. Find a local lab and you can have it tested pretty cheaply.
Treat it like it is unless you can rule it out.
Tags
asbestos , identification , insulation
Existing blow in insulation vs new insulation - Keep or redo? Jaxx Insulation 9 01-17-2014 08:26 AM
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Identifying asbestos insulation *PIC* Labut Insulation 2 08-06-2011 03:52 PM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
