Necessary To Replace Moisture Barrier That Was Ripped Out? - Insulation - DIY Chatroom Home Improvement Forum
Old 12-05-2017, 11:42 AM   #1
Rewards Points: 12
Necessary to replace moisture barrier that was ripped out?
I mistakenly posted this in the "concrete" subforum instead of this one. Our sump pump failed several months ago, requiring the services of a water restoration company. Unfortunately the technicians had to cut out the lower two-feet of drywall around the perimeter of the finished basement. Apart from that, there was no permanent damage. The crew also cut out the black plastic moisture barrier that was in between the studs and the poured concrete wall. I have purchased new insulation and drywall. I'm preparing to start putting everything back together, but I'm wondering how (or whether I even should) to replace the missing moisture barrier. We're in central Ohio and our house was built in 2005. There have never been any water or moisture issues apart from the failed sump pump. I've been researching moisture barriers in general and there seems to be varying opinions of whether it is helpful or harmful in a northern climate.
Is it necessary to replace this black sheeting that the technicians cut out? If so, I don't imagine that I could route it under the bottom of the base stud of the wall. How would I join it to the existing plastic sheeting (a special kind of tape, staples, adhesive, etc.)
Gouverneur is offline   Reply With Quote
Old 12-05-2017, 02:33 PM   #2
user_12345a's Avatar
Rewards Points: 36
Re: Necessary to replace moisture barrier that was ripped out?
That material is needed to maximize insulation performance; basement walls even with water proofing get damp, the moisture gets transferred to the insulation and r-value gets reduced.
It's better just to use rigid foam in a basement and forget about it.
Foam doesn't allow moisture or air to flow through it, it's a true thermal break.
Conventional insulation with vapour barrier isn't the greatest in a basement - vapour barrier isn't perfect, some moisture goes through, gets in. On the other side the concrete doesn't have good drying potential, it's a source of moisture itself.
Gets worse with a moisture barrier, moisture can get trapped in the wall and you can get condensation on the above grade part of the foundation.
While the moisture may not be enough to rot wood studs, it still reduces insulation r-value.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 12-05-2017, 02:44 PM   #3
Rewards Points: 12
In that case would you recommend that I replace the missing section of the vapor barrier with the rigid foam sheets?
Old 12-05-2017, 02:57 PM   #4
retired framer
Rewards Points: 292
It's all or nothing, are you going to remove the rest of the drywall?
Old 12-05-2017, 06:48 PM   #5
Rewards Points: 36
yah, if it's a small section and the rest of it will stay the same, there's no point.
just put it back to the way it was.
though if it's a large area it may make sense to look at alternatives. putting foam behind studs may be difficult.
moisture barrier question jackwashere Roofing/Siding 6 10-17-2012 08:15 AM
Air barrier moisture barrier ? Faced vs unfaced insulation ? Wind82 Building & Construction 6 03-02-2012 12:00 PM
Cleaning brush StevenH Painting 19 02-05-2011 11:13 PM
Moisture barrier for framing pennshaq Remodeling 0 07-02-2010 07:45 AM
moisture barrier - help! jediracer Carpentry 12 10-03-2006 06:32 PM
